flush is good, we can work with flush. :grin:
you need your mig welder, a washer( the same size as the grub screw) a nut and a pair of pliers.
to start with fill the grub screw hole with a weld from your mig welder, use a high setting to get heat penetration,
place a washer the wider the better over the grub screw and weld the washer to the grub screw, then weld a nut onto the washer.
you can now use a spanner to undo the nut, bringing out the grub screw with it. i have used this method on loads of occasions and it works 90% of the time
