13x7 Tyres
20 replies to this topic
#1 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 01:15 PM
im having alot of trouble finding 175/50 r13s and they are really expensice so i was thinking could i put 185/55 r13s on and what as everyone else done i can get the 185 dunlops fitted and balanced for about £40
#2 octagonalpaul
octagonalpaul
  • 353 posts
  • Local Club: shatrats.com
Posted 17 September 2010 - 01:24 PM
165 55 13s can be a bit cheaper, but they have more of a stretch depending on how wide your wheels are
#3 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 02:08 PM
they are 13x7s
#4 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Nottsaboutminis
Posted 17 September 2010 - 03:29 PM
whats wrong with these? they all say 'in-stock' :D
Link to tyres
#5 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 04:47 PM
i need them sharpish si i can fit the wheel archs but i need to know if the 185 tyre will rub inside the wheel arch ??
#6 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 05:25 PM
i can get a set of 185/55 r13s a set of 4 for 100 but ill have to get them fitted in the morning but i need to know if they will rub does any one know if they will
#7 mini13
mini13
  • 3,810 posts
Posted 17 September 2010 - 05:35 PM
they probably will rub, but then a set of 175's may rub too,
you could always get a set of rack limiters from KAD for a tenner.
#8 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 05:38 PM
hmm ok i have a set of deep dish with a big offset if that makes any diffrence
#9 wolfie
wolfie
  • 1,149 posts
Posted 17 September 2010 - 05:48 PM
getting 175/50/13's are not an issue at all
http://www.camskill....plid=m4b0s582p0
#10 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 05:51 PM
i know that but 1 i need them fitted this weekend and 2 i dont have 50 or more to spend on one tyre and a set of four works out quite alot so im asking for an alternative tyre like a 165/50 r13 or a 185/55 r13 and what it will do putting a tyre on that 10mm bigger
#11 Artstu
Artstu
  • 830 posts
Posted 17 September 2010 - 06:07 PM
Do the maths then you decide if they may or may not rub
http://www.club80-90...0calculator.htm
#12 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 06:15 PM
lol that dont mean any thing to me its aload of jibba jabba
#13 Artstu
Artstu
  • 830 posts
Posted 17 September 2010 - 06:25 PM
Or stick some 165/ 55's on with a nice stretch :D
#14 mab01uk
mab01uk
  • 12,446 posts
Posted 17 September 2010 - 06:27 PM
If you enter the sizes of the tyres compared with 175/50 x 13 in this special tyre size calculator below, you will then know the difference in diameter. Then go and measure the closest point on the car, likely to rub................probably the rear radius arm pivot / outer bracket.
http://www.tyresave....k/tyresize.html
#15 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 07:23 PM
there was loads of room on the the rear with the 175s i cld fit my hand between it and thats wider the 5mm so i rekon they will
