13x7 Tyres
20 replies to this topic
#16 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 September 2010 - 09:34 PM
But you're getting tyres that are 10mm wider and have a 14.25mm higher sidewall. They are a lot bigger all round.
#17 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 17 September 2010 - 11:05 PM
correct me if im wrong but they are 10mm wider wich will be 5mm each side i havent lowered my mini so the hight isnt a problem
#18 Ethel
  • 25,987 posts
Posted 17 September 2010 - 11:53 PM
You can't really judge the width, the widest bit won't be the tread and a taller profile will bulge more in the sidewall. I suppose you could always find a wheel in the scrappers to pattern up, it won't matter if it's a different pcd as long as you can offer it up to the hub.
#19 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 18 September 2010 - 10:38 PM
well this morning i thought id just go for it so i got the tyres fitted ill need to do slight modification i think in the wheel archs but not much when the engine is in it might change but other than that they fitted al right
#20 Sam Walters
Sam Walters
  • 2,765 posts
Posted 18 September 2010 - 10:44 PM
175/50/13 Yoko A539 Shouldn't cause an issue, your front arches should already be trimmed a sufficient amount.
205/45/13`s are another story mind. Rub on the front, the flitch panel on full lock too.
#21 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 18 September 2010 - 11:02 PM
i got 185/55 r13 and they rub a lil in the front and nearly the back
