so if you guys know im running a orion hcca 10.2 4000watts peak woffer.
its my first time building a box, i didnt want to go to the audio shop and spend over 100 pounds when i know ill be more satisfied making it myself and hell cheaper.
firstly i got measurement of course then carefully added them up to tune the box to 30hz with a 2.0 cbf (without sub woofer)
i used one of them subwoffer enclosure calculators you find on a google search
so the task is to build a box sounds simple huh?! WRONG!
the audio guys i get most of my advice from insisted i should use to 1inch thick mdf even up to 3inchs thick! he said he runs these in his motor and theyll just break any thing less then 1inch thick.
so i started off with a design and mini box so i could get my head around how itll all fit together with the joins ect...
http://i936.photobuc.../IMG_0219-1.jpg
http://i936.photobuc...ge/IMG_0235.jpg
this means yeh i have my calculations all added up but then i had to calculate cutting sixes for everything to fit together so i had to chop bits off the side bits off the top the vents everything and maths got crazyyyyyy! Went to BNQ and the guy who cuts the wood was really helpful cut and measured and check everything perfect.
only spent 25pounds on a sheet of 1inch thick mdf and cut! bargin !
http://i936.photobuc...ge/IMG_0233.jpg
In the end i got it all to add up ( you cant the L vent but its there! )
its not together yet thats tomorrows job !
http://i936.photobuc...ge/IMG_0236.jpg
http://i936.photobuc...ge/IMG_0237.jpg
And a cheeky little peak of my 1ohm woffer going in
http://i936.photobuc...ge/IMG_0238.jpg
Anyways ill add more pictures tomorrow
UPDATE***********************22/9/10***********************
last few days have been real tricky had a friend come over and look at the box and had to remeasure and tune the box in to what i originally thought it was going to be
the box has glued well and ive had to cut two sides of the L port by hand which was a right B****H with a saw, managed to do it all well and i have some updated pictures!
http://i936.photobuc...ge/IMG_0261.jpg
http://i936.photobuc...ge/IMG_0267.jpg
http://i936.photobuc...ge/IMG_0268.jpg
http://i936.photobuc...ge/IMG_0270.jpg
http://i936.photobuc...ge/IMG_0271.jpg
the new measurements added up to the box being tuned at 44hz keep u posted only got one side and one top to do now!
Got both sides on now its just the lid to do!
http://i936.photobuc...ge/IMG_0272.jpg
http://i936.photobuc...ge/IMG_0273.jpg
http://i936.photobuc...ge/IMG_0274.jpg Inside the box air tight!
23/9/10***************************NEARLY FINISHED
okay so i did the last side this morning it fitted 1mm out as all the glued has settled and moved everything out but sorted that due to a bit of sand paper and man muscle
ive just come up from doing the lid and screwing the sub into place the last thing i need to do is cut the connector block on the side so the wires can be connected inside out ill get pictures tomorrow
http://i936.photobuc...ge/IMG_0279.jpg Making sure everything fits nice!
http://i936.photobuc...ge/IMG_0281.jpg inside the box just about see the L port
http://i936.photobuc...ge/IMG_0285.jpg
Managed to find these bolt like things, i made the holes bigger and put the bolts though and as the sub sits on and tightens up the sub should fit real snug i was going to use self tappers but i know this woffers going to vibrate alot and may rip the box to pieces
http://i936.photobuc...ge/IMG_0288.jpg Using a few washers it all settled nicely
http://i936.photobuc...ge/IMG_0287.jpg I cut the hole dont laugh with a drill and a saw n then found a jigsaw which annoyed me alot hahaha
but the hole is perfect again using sandpaper got it all to match up good!
http://i936.photobuc...ge/IMG_0283.jpg TOP VIEW
Needs to be carpeted and the connector block and its finished!
Anyone got any other ideas instead of carpeting it?!
Edited by PartySausage, 23 September 2010 - 07:17 PM.
