Best Way To Store A Car For A Year
#16
Posted 21 September 2010 - 12:38 PM
#17
Posted 21 September 2010 - 12:57 PM
Do not put a cover on your car. It will make and keep moisture inside and rust the car badly! Not withstanding the fact that when it moves on the paintwork it will rub the paintwork away!
What you need is a carcoon like this:
What the carcoon does is take all the moisture out of everywhere in and around the car. Our cars will rust from the inside out. The carcoon will stop that happening.
Mine is a twin wall so can be used outside. The only time I get a problem is with heavy snow and I have to brush it off. These are used by all the classic car people.
To give you an idea of how good it is, I will tell you that I removed mine from the carcoon and someone from this forum was going to fit new leather covered seats for me. He did not turn up on several occasions and the Mini was left in a large garage I own for about three months. This was the first time rust actually came through and on the corner of the bumpers. The car was totally re built in 2001 with a new shell and has always been kept safe. Those three months were the worst it had ever suffered! I have since paid to have the bumpers resprayed.
Web site:
http://www.carcoon.co.uk/
I paid £373.29 with vat for mine in 2007
Cost me more than that to get the bumpers and a little bit more resprayed!
Hope that helps.
Best regards
Chris
#18
Posted 21 September 2010 - 01:00 PM
#19
Posted 21 September 2010 - 04:16 PM
it hasnt got any petrol in it at the moment, (well it might have a drop) so i think ill just leave it like that.
thanks for your help everyone!!!
#20
Posted 21 September 2010 - 04:39 PM
Yep, petrol going off does seem to be a myth. I started my old Mayfair a few months ago, which had about half a tank of petrol in it for four years and it started fine... (The rest of the car was in a very bad way, so all other storage related ideas seem to be real!)The petrol side of it. I inherited a 1989 orion and it had a full tank of petrol and had been sat for 9years and not started i put new battery on it and it started with 9 year old petrol. and run fine.
Edited by l_bratch, 21 September 2010 - 04:40 PM.
#21
Posted 21 September 2010 - 05:32 PM
i think fuel going off effects race engines more than anything when i used to race motocross if i left fuel in for too long about a month usually you would find the bike starting to run rather rough and not be nearly as responsive but drain the fuel out and put fresh in and it would be fine after a couple of minutes ridingYep, petrol going off does seem to be a myth. I started my old Mayfair a few months ago, which had about half a tank of petrol in it for four years and it started fine... (The rest of the car was in a very bad way, so all other storage related ideas seem to be real!)The petrol side of it. I inherited a 1989 orion and it had a full tank of petrol and had been sat for 9years and not started i put new battery on it and it started with 9 year old petrol. and run fine.
#22
Posted 21 September 2010 - 05:43 PM
Sitting it on blocks wouldn't do any harm so not a bad idea, as someone else has said leave the brakes off and if you can jam the clutch on then great. If it is in the air you can turn the wheels half a turn every now and again to stop them sticking.
With regards to the petrol tank- it is best to keep tanks full. In the plant/construction world drivers are told to fill their tanks every night to stop condensation rusting them inside, this should be no different with a car, but obviously it isn't a nice thought to fill it up with the expensive stuff knowing it's not going to be used for a year! (Although you'll be happy if petrol is £5 a litre next year!!!)
Starting and running should only be done if you can run it for a good half hour if being left for that long- and ideally should be driven- not just left to idle. This way everything gets warmed up thoroughly and water/condensation evaporates from the exhaust etc so it won't start to attack the steel when warm and still damp. It will also keep your brakes and flywheel surface in good condition.
Got to be honest about the battery- I'm not sure how it will react to not being used for a year- and I wouldn't have thought leaving it on charge for that amount of time would be wise, I'd have thought maybe be put on trickle charge for a couple of days every month or two, and being used to start the car if you can use it may help.
Hope that helps?!
p.s. nobody has advised on any way of keeping it smelling fresh inside and not going musty! I dont know much about this but it could be an issue!
#23
Posted 21 September 2010 - 05:45 PM
#24
Posted 21 September 2010 - 06:17 PM
i have just bought a breathable car cover of ebay. £12 YAY! (halfords £65 - go **** urself!!)
so ill just stick that on there.
i wont be able to drive the car as it has no tax, mot or insurance. but i can still run it for half an hour atleast when i come home for holidays.
i just need to get a demister thingy to go on the inside.
cheers everyone.
#25
Posted 21 September 2010 - 07:23 PM
#26
Posted 21 September 2010 - 07:32 PM
it would be mum who would use it and im not sure she would like it for a whole year.
and then it needs tax mot and insurance just to keep it going well. its gonna cost atleast £400 for that year.
#27
Posted 21 September 2010 - 07:42 PM
This is the fuel that came out of my mini tank after 4 years, you could make sure it's empty, then put it somewhere warm and dry for a while, then put a litre of oil in and give it a good shake to coat it all, just rince it out with fuel in a year!
#28
Posted 21 September 2010 - 07:59 PM
#29
Posted 21 September 2010 - 08:04 PM
#30
Posted 21 September 2010 - 10:12 PM
Those carcoons are a brill idea! Libby what size is yours? Size 2?
Hi,
Cannot remember what size, but I gave them the car and they told me what size.
To the original poster.
The carcoon is a very low cost option if you value your car. If it has no value then I agree it is not worth spending the money.
However, your breathable cover will let damp in which will cause rust and wind moving the cover will damage the paintwork. It this does not bother you and you are happy to pay to sort this out or leave it then of course that is not a problem.
I bought a breathable very expensive and soft cover for Libby and after a month or so the paintwork was damaged. This is the reason I researched and found out the carcoon was used by a lot of owners with expensive classic cars.
The carcoon power supply also includes a trickle charger which I don't use as the car is driven at least every month.
Best regards
Chris
