I'm looking to upgrade from the drums on my 63 Mini.
I have done a search (quite hard when there's a limit on words under 4 characters!) which has given me some information but I have some specific questions.
1) I want to keep my 10" Minilite alloys - Can I use the aftermarket 4 Pots and 7.9" solid discs or would I be better off with the Cooper S setup?
2) My Mpi Cooper stopped really well - would the 4 pots be better even though the disc size is smaller? How would the Cooper S setup compare to the Mpi?
3) Would I need to fit a servo or will I be ok with the standard set up? If so what servo fit straight on?
4) Can I buy second hand 8.4" shafts, hubs and flanges off ebay etc to reduce costs if I went for the 4 pots?
5) Brake lines/hoses - What do I do here?
6) Rears - can I just fit super fins / mini fins and longer studs - someone metioned the cylinders need changing too.
Edited by JimCooper, 05 May 2011 - 01:22 PM.
