Mk1 Brake Upgrade
20 replies to this topic
#16 JimCooper
JimCooper
  • 141 posts
  • Local Club: Redditch Mini Owner's Club
Posted 06 May 2011 - 12:09 PM
anyone that can help with this please?
#17 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 06 May 2011 - 12:42 PM
Sounds like you need to adjust the pressure bias valve.
#18 JimCooper
JimCooper
  • 141 posts
Posted 06 May 2011 - 03:46 PM
Where's that located please and how do i do it :thumbsup:
#19 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
Posted 06 May 2011 - 04:34 PM
Depending on the age of the car or the brake system used it can be either on the bulkhead somewhere or on older models it's bolted to the rear subframe. Just follow your rear brakeline and you will find it. Turning it in will reduce the pressure the backside receives, afaik. You may of course also not have one in the first place, which would explain your problem with the rears locking up before the front disks do.
#20 Spitz
Spitz
  • 1,716 posts
Posted 06 May 2011 - 04:40 PM
Maybe you should have gone with the smaller bore rear cylinders GWC1131
#21 JimCooper
JimCooper
  • 141 posts
Posted 07 May 2011 - 08:35 PM
Thanks for the reply, I have the bias valve on the bulkhead but not sure where the adjuster is on it, in the centre there is a through bolt that holds it to the bulkhead and nothing else unless its the big bolt on the end?
I have already changed the rear cylinders as I thought that would solve it but it hasn't :D
