What kit to get?
#16
Posted 06 December 2005 - 10:54 PM
http://www.caraudiod...d1ba7d0399c37b1
its 300W less than the one on ebay and its under the "multi channel" parts of the amplifier section? what exactly do they mean by multi-channel? take a looksy, sorry for my noobishness hehe.
Tom
#17
With a sub the position, angle or the way its fitted on the box isn't as crucial as a midrange or tweeter.
The mids and tweeters should ideally be firing at you from in front (at ear level is ideal but not really possible in a car) and should be the same distance from each ear to acheive near perfect sound. They should not be obstructed in any way.
Obviously in a car this is hard to achieve, so people mess around with the angles of speakers and even phasing to acheive as good a sound as possible. You can have the speakers at ear level, firstly because there is nowhere to mount them and also because you will end up with one speaker a lot near to your head than the other (left and right).
If you want an example of how bad an inverted midrange or tweeter will sound put you hand over the front of the grill on your pc speakers and play some music, it will sound muffled because the sound is being obstructed.
could you not mount them like this with some sort of build to get enough depth, you can get some speakers which are really shallow.
Posted 06 December 2005 - 10:55 PM
Tom
#19
Posted 06 December 2005 - 10:58 PM
I only wanted to turn the rears upside down, do you think this would be a problem? if it is il figure some way of mounting them differently
what you drew is pretty much the same thing I was thinking for the front, they will be pointing down slightly though, will that matter at all?
The componant system you suggested would be a bit too big, would it be ok using the same system, but the 5" JBL one? its on car audio direct. looks the same as the other one but smaller.
Thanks again
Tom
#20
Posted 07 December 2005 - 12:07 AM
This is the sort of thing Im going for, obviously theres another speaker on the left but I cant draw it in paint lol.
anyone see any flaws in the plan at all?
Id like to turn the speakers upside down too if poss?
Tom
#21
Posted 07 December 2005 - 07:33 AM
bass is omnidirectional.
The smaller speakers produce directional sound, and the actual music coming from the speakers travel a smaller distance, and are also affected by seats etc being in the way.
Subs with there low frequencies will go through the seats.
Basically you cannot turn the small speakers upside down and get a good sound out of them.
Higher frequencies=directional and short distance
Lower frequencies=Omnidirectional and longer distance
#22
Posted 07 December 2005 - 09:49 AM
the subs would look pretty cool upside down, would 2 free air subs work in those positions? and what sort of sound would it give me?
Tom
#23
Posted 07 December 2005 - 12:49 PM
However, the volume of the box is very important!
#24
Posted 07 December 2005 - 01:40 PM
my mate did the same and without screwin 'em in turned it on and his speakers shot out of the holes!
#25
Posted 07 December 2005 - 11:49 PM
you need to calculate the exact volume of the enclosure also for the sub to operate correctly, using a sealed enclosure (without ports) is the easiest option (and uses a smaller box), you can port the box but it generally makes the box quite large and is harder to do (porting is an exact science, get it right you'll be laughing but done wrong it will sound rubbish)
#26
Posted 08 December 2005 - 05:29 PM
Does anyone know how to work out the volume of a box that sort of shape? Im hopeless!
Thanks again for the help.
Tom
#27
Posted 08 December 2005 - 05:37 PM
I prefer to put subs in seperate enclosures to each other but they can go in the same.
#28
Posted 08 December 2005 - 06:00 PM
Do you think that 2 10" subs would be the way to go?
Do you know any good rears that I could use?
All the best
Tom
#29
Posted 08 December 2005 - 06:29 PM
#30
Posted 08 December 2005 - 06:49 PM
