Seat Lowering
20 replies to this topic
#1 EatSleepJDM
EatSleepJDM
    previously known as 88minicity
  • 631 posts
  • Local Club: Blakehill Minis
Posted 09 October 2010 - 02:13 PM
I've been trying to think of a way to do this but i haven't got a clue so was wondering if any of you have done this.
I've got MPI seats in my mini, moved back as far as possible but my ankles don't like it :o . So i'll fit some of those extender brackets but then i'll have to tilt the seat-back forwards to avoid rubbing on the rear bin. This will result in my head rubbing on the headlining so I don't want to til the seat forward really.
So I was wondering if there is a way of making the seat sit lower to the floor? So then I can fit the extender brackets and then tilt the seat-back forward to avoid the bins, and my head will then not rub on the headlining :)
Is there a way of doing this?
#2 crazycoleman118
crazycoleman118
  • 836 posts
Posted 09 October 2010 - 02:27 PM
how tall are you? and the only way i can think of would be too make custom seat bracket/mounts to your spec
#3 EatSleepJDM
EatSleepJDM
  • 631 posts
Posted 09 October 2010 - 02:54 PM
5ft 11 i think :)
Could i put some sort of spacers on the seat brackets and move the seat to the left a smidge just to avoid the bin? Might have a go at that actually and see what happens
Edited by EatSleepJDM, 09 October 2010 - 02:54 PM.
#4 crazycoleman118
crazycoleman118
  • 836 posts
Posted 09 October 2010 - 02:59 PM
im suprised you need the brackets, i ran standard seats with no problems, and now running corbeau clubman buckets on standard brackets, and im 6ft
but yeah try that, maybe put them the other side of of the bracket with a longer bolt so it still fits through the bracket all the way
Edited by crazycoleman118, 09 October 2010 - 03:02 PM.
#5 tom3112
tom3112
  • 346 posts
Posted 09 October 2010 - 03:02 PM
I'm 6ft'1 and have no problem when the seat is fully back. (I have longer legs and shorter body) :)
#6 cagy
cagy
  • 892 posts
Posted 09 October 2010 - 03:03 PM
I'm about 6ft (long body short legs) and have never had a problem, i think it depends on your driving style as i know that i don't mind having my knees under the steering wheel others prefer their legs as straight as possible etc
#7 tom3112
tom3112
  • 346 posts
Posted 09 October 2010 - 03:04 PM
My legs go either side of the steering wheel, and it's very comfy :)
#8 EatSleepJDM
EatSleepJDM
  • 631 posts
Posted 09 October 2010 - 03:07 PM
Ahh yeah think it's all down to taste isn't it. The back of my knees absolutely kill when i'm driving it as it is at the moment, same with my ankles :) Never thought my legs were particularly long but they must be! :o
#9 pikey7
pikey7
  • 3,824 posts
Posted 09 October 2010 - 03:11 PM
I had buckets mounted on the floor behind the crossmember, and on a long drive my ankles still killed. I did see somewhere... but don't ask me where i don't remember, a set of seat adapters that mounted over the crossmember and gave you the same seat attachments as standard, but behind the member. I guess those would work for you. If i find em, i'll post back, but a google wouldn't kill ya :)
#10 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 09 October 2010 - 05:04 PM
i'v got the extension brackets and the seats out of my 93 cooper in the mayfair and they foul the bins, got a hole in the drivers seat where it rubs :)
if spacers were to be put in that bring the seat closer to the middle of the car would they be a bit of a danger in an accident or is the seat the last thing i need to be thinkin about if i'm in a accident?!??
#11 Robbie
Robbie
  • 517 posts
  • Local Club: Renegade Mini Fun Club!
Posted 09 October 2010 - 06:03 PM
I'm 6ft 3, and I get on fine with just the extension brackets. I've got SPi half leather seats in mine, and even tilted quite forward my head's not near the headlining.
#12 EatSleepJDM
EatSleepJDM
  • 631 posts
Posted 09 October 2010 - 06:05 PM
Well I'm not comfy driving him as the seat is now so I've got to do something. I don't know why my head hits the headlining though :D|
#13 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 10 October 2010 - 06:46 AM
look on here,
http://www.m-machine...ew_Products.htm
they make a ting called a reverse seat mounting bracket, just weld it in and you can have your seat mounting on the other side of the crossmember,
and since you put it in, you can have it as far left as you like!
#14 digler
digler
  • 439 posts
Posted 10 October 2010 - 02:15 PM
the mpi seats are bigger than the earlly seats, so they wont move back for the bins.
what i did with mine is i modified the seat. i cut about 1.5 inch out of the legs to lower the seat, and i welded the
the leg on the inside on an angle, so the back of the seat can move closer to the tunnel.
then i made some brackets to move the seat back.
#15 EatSleepJDM
EatSleepJDM
  • 631 posts
Posted 10 October 2010 - 03:19 PM
look on here,
Cheers mate! After looking over the seat today I'm not sure if i can move it left because of the lever catch thing under the seat that hooks under the black rail near the tunnel >_<
What seats do you have in yours?
Sounds like a good setup though, does it work well?
I fitted those extender brackets today and it was no good, had to tilt seat forward to avoid bins and my head was hitting the headlining.
Gonna see how it goes with the more i drive it, but may have to modify the seat if it gets too uncomfy :/
Thanks for all your help :)
