iratic idle
Posted 07 December 2005 - 08:40 PM
Just wondering if anyone had any idea as to where I should begin looking to cure the following problem. Basically the alternator had died and I replaced it and that part is fine, however, when the engine idles it jumps up and down and almost stalls. What should I be looking at to rectify this prob.
Any help or advice is going to be much apprecited.
Justin D.
Posted 07 December 2005 - 08:53 PM
For different problems
Posted 07 December 2005 - 08:56 PM
Posted 07 December 2005 - 09:23 PM
Posted 07 December 2005 - 11:39 PM
Posted 08 December 2005 - 12:05 AM
http://www.theminifo...topic=10173&hl=
http://www.theminifo...topic=12722&hl=
http://www.theminifo...88&hl=injection
http://www.theminifo...56&hl=injection
http://www.theminifo...90&hl=injection
http://www.theminifo...08&hl=injection
http://www.theminifo...07&hl=injection
http://www.theminifo...showtopic=20293
Edited by Mini Sprocket, 02 February 2006 - 11:22 PM.
Posted 08 December 2005 - 07:56 PM
Posted 08 December 2005 - 08:05 PM
Posted 23 December 2005 - 08:04 PM
Posted 23 December 2005 - 11:08 PM
The relay supplying the heater of the Lambda sensor can fail, causing the sensor to read rich at idle as it runs cooler, causing the ecu to 'lean out' the fueling and resulting in lean missfire at idle. All other driving conditions are fine.
My SPI is now running tip top as it should be with no comlaints
Posted 30 December 2005 - 08:28 PM
Bosch oxygen sensor part number is........0258 003 193
And use this link to find your local Bosch stockist/ motor factor
http://www.boschauto...oduct&intType=1
Edited by Mini Sprocket, 30 December 2005 - 08:33 PM.
