Got most of the wiring sorted (i think) but there are a couple of loose ends I need to tie up that i need some second opinions on.
Firstly the fuel pump
Im using an MPi tank and fuel pump as this seemed the simplest route to getting up and running.
My question is the wiring up of the fuel pump to the 5PW loom. I believe the solid grey wire (on the bike loom) is for the fuel pump but does it just go directly to the connector on the fuel pump? I also have the white/purple fuel pump wire from the mini loom. Is it as simple as connecting them both to the fuel pump connector on top of the tank or am I missing something?
Next one is the wiring from the rectifier.
Does the red wire go to the starter relay on the battery side?
Is there a specific place for the earth wire to go to or can it just be earthed on the bodyshell?
thank you
Wiring Questions
racerlike
, Oct 12 2010 06:45 PM
No replies to this topic
