This probably won't be helpful, but hopefully enlightening.
Exhausts are not straightforward. What works on one engine extremely well may not be the optimal on the next. Even the smallest of changes - shape, dia, location of silencers, diameters, etc - all have big impacts. The only practical way you'll find out is to try a few. Bigger is not always better and what works in one power range, is not likely to work across the range.
A simple experiment you can try is to have a short section of exhaust made, say 4" long that fits on to the end of your current exhaust, slip that on and go for a drive.
As so many times before..., you are absolutely right and I am aware of the circumstances. I was more after a pointing in the right direction. On other engines (street engines tuned to different extent, 1293-1400cc), I have favoured the twin box, side exit RC40 system (1"3/4) with a std bore LCB. On this engine, I think it can result in to high gas speeds why I am considering bigger diameters.
