Cigarette Lighter
Posted 19 October 2010 - 09:08 AM
thanks danny
Posted 19 October 2010 - 09:17 AM
Posted 19 October 2010 - 09:22 AM
would i just put a inline fuse then a wire straight to that fuseBest to wire it to fuse 3 (25 amp) in the fuse with box with an inline fuse (around 15A). So the inline blows out before the main fuse, taking everything else with it.
Posted 19 October 2010 - 09:27 AM
Yes, basically you draw a new wire from fuse 3 and connect it to the in-line fuse. and connect the other end of the in-line fuse to the cig lighter. Make sure the in-line fuse is accessible so you can replace the fuse if needed.
Forgot to mention, make sure the wire is the correct gauge for 15A.
Posted 19 October 2010 - 09:30 AM
nothing complicated atall
Posted 19 October 2010 - 09:33 AM
how will i know if it is the right gauge ?would i just put a inline fuse then a wire straight to that fuseBest to wire it to fuse 3 (25 amp) in the fuse with box with an inline fuse (around 15A). So the inline blows out before the main fuse, taking everything else with it.
thanks dan
Posted 19 October 2010 - 09:39 AM
You need to make sure the wire is stronger than the fuse so that the fuse breaks and not the wire.how will i know if it is the right gauge ?would i just put a inline fuse then a wire straight to that fuseBest to wire it to fuse 3 (25 amp) in the fuse with box with an inline fuse (around 15A). So the inline blows out before the main fuse, taking everything else with it.
thanks dan
Posted 19 October 2010 - 09:40 AM
Have a look at this site. it has a guide on the wires and their usage.how will i know if it is the right gauge ?would i just put a inline fuse then a wire straight to that fuseBest to wire it to fuse 3 (25 amp) in the fuse with box with an inline fuse (around 15A). So the inline blows out before the main fuse, taking everything else with it.
thanks dan
how would i know ive got some wire here with me know will it say on the wireYou need to make sure the wire is stronger than the fuse so that the fuse breaks and not the wire.how will i know if it is the right gauge ?would i just put a inline fuse then a wire straight to that fuseBest to wire it to fuse 3 (25 amp) in the fuse with box with an inline fuse (around 15A). So the inline blows out before the main fuse, taking everything else with it.
thanks dan
Posted 19 October 2010 - 09:45 AM
I was going to ask this question today as well, are there wires that all ready come out of the 'fuse 3' that you mention? Do they run up the steering column?
I was gonna get my dad to do this job as I am completely inexperienced, but we were thinking of putting on a snapper connection onto one of the wires that are are exposed on the column then use an in-line fuse for protection.
Do you know where I can get a wiring diagram on-line for my model?
Posted 19 October 2010 - 09:47 AM
Posted 19 October 2010 - 09:49 AM
Posted 19 October 2010 - 09:56 AM
Posted 19 October 2010 - 09:58 AM
Posted 19 October 2010 - 10:00 AM
i dont think i can use it its a solid wire not smaller wires wrapped together but it 1-2mm thinkmini danny what size cable is the cable that you have it should say on it in mm
