Rev Counter
Posted 09 December 2005 - 12:58 AM
Roo
xXx
Posted 09 December 2005 - 01:19 AM
Have a look here at
Demon Tweaks
and
Minispares
Posted 09 December 2005 - 01:20 AM
Posted 09 December 2005 - 10:34 AM
hope this helps roo too!
Posted 09 December 2005 - 10:45 AM
Posted 09 December 2005 - 12:07 PM
Roo
xXx
Posted 09 December 2005 - 01:01 PM
As mentioned, the wires supplied with the units are usually short and you should plan on having to extend them. If you must pass any wires through the firewall, be sure to use a rubber grommet. Don't pass the wires through a bare hole in sheet metal.
Early Minis never had tachs. I'm not sure when they started showing up as factory items. Sticking with Smiths is fine, but in the case of an older car... you can't say because it's because of "originality". I like VDO gauges. They are high quality and highly reliable. I've seen very old VDO instruments which work like new (including being in calibration) after decades of service. Modern Smiths units (from Caerbont) will probably be better than older Smiths units. If you opt for Smiths (used from a scrap yard), don't pick up any gauge labeled "RVI" on the front, they are current sensing which makes them incompatible with electronic ignitions and they are harder to connect. Gauges marked RVC on their faces will generally last longer and are easier to connect to your car.
by the way (and this is important), the color codes I mentioned above are for "modern" gauges. I don't believe that Smiths (even today) uses those colors. Always install as your gauge maker says paying attention to the color codes in their instructions.
Posted 09 December 2005 - 07:42 PM
:erm: Thought I explained that to you the other nightsorry to but in but the 3 wires you are talking about are they loose or do you have to splice on to them? the wiring on my mini seems to be every where.also what colours are they? cheers miniman :grin:
I'll check the wiring on my mini on sunday and give you the correct colour wires and which ones need splicing if at all
Roo
Is your car a carb or injection? I forgot :nugget:
Posted 04 January 2006 - 10:17 PM
Also i thought that the hand on the dial as turned by a cable? Or am i too old fasioned???
Posted 04 January 2006 - 10:30 PM
Posted 04 January 2006 - 10:31 PM
I found this
Clicky
Can it just bolt into back of my bit of wood (dashboard) and i then connect wires behind to places? lol :S
Edited by ashmeadant, 04 January 2006 - 10:47 PM.
Posted 05 January 2006 - 03:39 PM
New quality tachs can cost serious money. VDO is quality and generally the components last longer the Smiths units. These regularly show up on eBay. I've got a couple of VDO units from the early 1970s that still are accurately calibrated after all these years.
The scrap yard may have some old Smiths units. If you look for one of those, make sure it says RVI on the face somewhere as these are much more compatible with later ignition systems.
Posted 05 January 2006 - 06:33 PM
Also make sure you get the black dashboard trim from either side, as they are a different length to the two clock.
There is one big multi plug, to swap over, and the speedo cable. Then once the new clocks are fitted, there is some simple wiring for the rev counter itself.
Try and get the clocks from a similar age car with the same size wheels 12" or 10"
so the speedo is the same.
otherwise some swapping and changing of the individual dials may be required
Posted 05 January 2006 - 07:01 PM
Posted 05 January 2006 - 07:16 PM
