Fitting 4 Spot Lights
Brams96
, Oct 27 2010 08:31 PM
17 replies to this topic
#16
Posted 27 November 2010 - 09:54 AM
Excelent pics, thanks. I take it there are bolts that screw in through the subframe directly into the ends of the bracket? This looks like a brilliant design I will definitely have to 'borrow' the idea when I make up my own bracket.
#17
Posted 27 November 2010 - 03:31 PM
No problem!
....& yes from memory I think you simply re-use the standard subframe bolts and bolt them into the tubing to secure the lamp bar in place.
#18
Posted 04 June 2011 - 03:29 PM
Try Demon Tweeks for proper lamp bars,they fit direct to the body,bolt your Cibies on,then lamp steady bars to the body below the bonnet.Takes about 30mins to do,look better than tube,and,mini's only look good with Cibies on.
