Drift the roll pin?
7 replies to this topic
#1 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 18 April 2004 - 11:52 AM
See pic below.
I need to remove the extension rod on the later type rod change remote control gear system.
Haynes manual says "where extension rod meets selector shaft, drift the roll pin out"
How do I drift a roll pin out????
#2 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 18 April 2004 - 12:47 PM
Put the car in 3rd gear and with the right size drift (you can buy them for it) knock it out. They take a bit of doin sometimes and it can be awkward to get a good swing at it with a hammer, but it will come...
#3 adam c
adam c
  • 466 posts
Posted 18 April 2004 - 01:08 PM
ahhh thats what i did wrong - i tried to drift mine in neutral and it wouldn't come out - think I knocked out the other one in the end. (i think there are two, one horizontal and one vertical not sure whihc one is sposed to come out??)
#4 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 18 April 2004 - 03:03 PM
Cheers,
Any idea where I can buy the right sized drift from?
#5 bluebottle
bluebottle
  • 844 posts
Posted 18 April 2004 - 03:55 PM
you want a 3/16 parallel punch, try halfords or your local tool shop
i've always found it easier to knock out in reverse gear.
#6 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 18 April 2004 - 05:14 PM
if in an emergancy you can use a large nail and hacksaw the end flat (but best to use the proper drift for the job) dont be tempted to use a punch as the taper expands the roll pin and makes it tighter ! :grin:
#7 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 18 April 2004 - 10:01 PM
Much appreciated everybody
#8 siggy
siggy
  • 1,110 posts
Posted 18 April 2004 - 10:24 PM
I always do it this way. Netural gear, clamp a pair of mole grips on the gear change rod, so that the weight of them twist the rod clockwise and then tap it out.
Siggy
