and if possible what would you do to prevent it happening again?
(I know this sounds like a school exam question but there's a very good reason behind this lol)
Hang on a minute lads, I've had an idea
I will edit this post, with the list and then add the prevention or fix (some can't really be prevented as such)
Alot of the ones I have missed are just down to maintenance, obviously if you look after your car, it will look after you.
Gearlinkage roll pin coming out/breaking:
Carry a spare and make sure you fit a new one when you do a engine change, I put a cable tie over it just to make sure
Points closing and other ignition issues:
Convert to electronic ignition, carry a spare set of HT leads, cap and rotor arm + maybe a coil as they seem to be a common part to break or convert to megajolt but even a megajolt isn't indestructible
Electrical failures:
Carry spare fuses and wire, maybe a few connectors, wire can be used to fix a number of things too, mainly to hold on my exhaust when it fell off on the motorway.
Wheel bearing failure:
Ensure they have enough grease and there is no play in them, on VERY long trips I would possibly consider taking spares
Overheating:
Make sure you have the correct thermostat, flush out the cooling system when you service your car, maybe use water wetter and make sure your rad is in good condition and enough to cool your modded engine. I will be fitting the 12v aux fan I bought from ebay for £20 on a switch so I can flick it when I come to traffic or when the temp gauge gets high, I'm also fitting a capiarly gauge. Also make sure you have the correct cap. Maybe carry a container to fill up with water or even a container with water in it.
Snapped fan belt:
Carry a spare, they can also be used to more than one thing and change when the current one starts to wear, make sure it's the correct size too!
Coolant hoses popping off or simply exploding:
Carry certain spare hoses and jublie clips for long distances, change when they're worn. Ensure all hoses are connected properly and not right on the edge.
Flat battery:
I have had to push my mini up hill to let it roll forward to bump start it, it would be a good idea to carry some jump leads or a booster pack. Maybe fit a buzzer, so when you open you're door with the lights turned on, you will be reminded.
Exhaust falling off:
The spare fan belt you carry and the wire will come in handy for botching it back on to get you home, obviously you need to make sure it attached properly so it doesn't come off.
Slave cylinder and brake failure:
Make sure you replace all the seals and brake fluid from time to time, on a very long trip I would carry a slave repair kit and some brake fluid
Diff braking
Fit X-pin
Engine seizing
Fit oil pressure gauge, maybe adjustable pressure regulator, maybe carry some spare oil
Flat tyre
Tyre weld, spare tyre, is runflats on a mini possible?
Electrical fire
Make sure you're wiring is half decent, fuses not too highly rated for the wire/item and make sure the wires are of ample size for the job. Also ensure there are grommets in the correct places so no wires are rubbing againts a sharp edge, also make sure nothing is rolling around in your boot that can short the battery
Carry a fire extinguisher
Screws from air filter going into engine
I've heard this happen a few times, it's kinda why I like a ram pipe with a sock filter, make sure they're tight! + locktite
Fuel pump
You can get a SU electronic fuel pump that is like 2 pumps in 1, if one fails you switch the wires over and the other one comes in, something along those lines. Personally I'm just fitting a facet red top.
(Not finished yet)
Edited by danrock101, 04 November 2010 - 07:24 PM.
