Had a fairly lucky one today. Just as I parked up at work, a lower ball joint came apart!
Luckily it somehow undid itself, and popped out. Had some major camber on the front. Got it sorted in the end, put it back together, made sure it was tight, and folded down the flap-bits to stop it happening again!
I really need to change all the ball joints really...
Common Causes Of A Breakdown
danrock101
, Nov 02 2010 09:01 PM
49 replies to this topic
#46
Posted 08 December 2010 - 01:50 PM
#47
Posted 08 December 2010 - 09:37 PM
oh what memories are flooding back.In my teens in 1st mini, a 1970 1000 the throttle cable broke. Had some pliers and things luckily, connected the choke cable in place of the throttle and got back like that. Could only get about 1/2 throttle as I recall.Slightly odd driving experience. Clutch master or slave cylinder went on another occasion cant remember now, and got back 20 miles with no clutch-teaches you how to synchronise gear changes
#48
Posted 05 January 2011 - 01:27 PM
Broken down a few times (custom wiring is a *******!)
Dodgy ignition relay, A-force came couldnt figure it out wiggle the relay and it works again
Exhaust fell off (idiot who had the car before me didnt fit it right)
Exhaust almost falling off (Mini goes loud!!!!)
Alternator seizes - fan belt snaps - Boils all the water A-force towed me to unipart shop and i fit a new fanbelt and alternator
Ignition switch Melted itself - car cuts out (I have a toggle switch and push start) A-force bodged repaired first time, second time I did what the A-force did the first time
Flat battery (ALMOST EVERY MORNING!)
Car is currently in the mini center having things all fixed and sorted.
#49
Posted 05 January 2011 - 03:10 PM
Do Minis breakdown, or do parts that have been overused and not replaced just give up?
There lots of foibles on my Mini, any one of which could cause me to breakdown - and no doubt one probably will one day, but this is my own fault for not replacing parts that need replacing.
#50
Posted 05 January 2011 - 03:49 PM
incorrect tuning and wet electrics.
Solved with a rolling road tune, and fitting a plastic sheet behind the grille (not paying 40 quid for an ignition shield when half the time they dont do much)
Edited by Carlzilla, 05 January 2011 - 03:50 PM.
