Steering Column Size
Posted 14 November 2010 - 08:39 PM
Can anyone please tell me what size steering column do the two brackets in the Zcars frame take please?
Ive got a 19mm/ 3/4" stainless steel column assembly that Im hoping would fit.
Thanks.
Posted 15 November 2010 - 02:56 PM
What are you using for UJ's?
Posted 15 November 2010 - 07:19 PM
Ive also got 2 supports that are 19mm rose joints with a long thread that I was going to bolt through the frame, or make up some sort of billet block that fits round the Zcars frame and the rose joint bolts to. But if the standard supports take a 19mm shaft I will use those. Just wanted to check incase I needed to see if I can order the frame without any brackets.
Edited by benmoffat, 15 November 2010 - 07:22 PM.
Posted 15 November 2010 - 09:44 PM
Thanks for the reply. Basically it consists of a 19mm stainless steel column, and a billet UJ from Car Builder Solutions (UJ Link)
i used a mk3 fiesta steering column, the uj's fit straight onto the mini rack and it also has 2 uj's that are quite close to each other which helps reduce the usual severe angle the standard mini steering wheels sit at. i bought 2 bearings from ebay with brackets for around £18 and one was 25mm and the other was 15/16ths, and they fit over the fiesta rack and the bearings have 2 grub screws that hold the bearings to the column, very tidy once it is fitted
cheers,
Ed
