Edited by mini danny, 21 November 2010 - 06:34 PM.
Decent Air Compressor
Posted 21 November 2010 - 06:32 PM
Posted 21 November 2010 - 09:16 PM
Posted 21 November 2010 - 09:47 PM
I've got both single/three phase ones, the main one I use is my Clarke Air one (huge blue ones but they come in smaller ones)
Posted 22 November 2010 - 09:03 AM
Posted 22 November 2010 - 11:52 AM
hiya looking for a air compressor what compressor would you recommend dont want something to pricey thanks Danny
All depends what you want to do with it...
Posted 22 November 2010 - 08:14 PM
You kind of get what you pay for - but cost/quality usually boils down to how much you will use it.
We pump up wide 13" tyres with a portable cheap compressor (local car shop type) using a 12volt battery on a battery stand - It will do all four tyres before it kills a car battery.
If it did not need to be portable we would go 240volt. Even then you need to keep in mind your larger CFM machines will require a bigger fused supply than your normal socket ring main - More like the amperage of a cooker point feed. If it's on a three pin domestic plug you will be ok. if your painting you need to consider more than just the compressor too..
There is a maximum HP motor you can run of a 13 amp plug.
Posted 22 November 2010 - 08:20 PM
Posted 22 November 2010 - 08:44 PM
Cheap direct drive compressors are hellish noisy, the more expensive belt driven ones are a LOT quieter.
Right now you think that as you won't be using it very often the noise won't matter??
Tell me after using the dammed thing for painting a car for an hour or so that noise doesn't matter.
Posted 22 November 2010 - 08:46 PM
haha you do make me laugh lol and getting it done paint done professionally just to prime panel by panel once there done and think ill get a decent one with little noiseThe first air compressor you buy will be on price, the 2nd air compressor you buy will be on noise levels!!
Posted 22 November 2010 - 08:59 PM
EG, an average DA will use between 3-4 CFM ( Cubic Feet per Minute ) of air, based on a 25% duty cycle, that is for every minute you're only using the DA for 15 seconds.. if you're using it 100% then you're going to need a compressor which pushes out between 12 and 16 CFM..
I have one of those little "Aldi" compressors in the garage, just to run an air drill to put the bolts into cases, after 10 bolts that's the air's gone.
Posted 22 November 2010 - 09:14 PM
And screw or vane compressors are quieter than pistons...
Like this if you have enough room
Posted 22 November 2010 - 09:16 PM
waaay to big lol need to be compact do i can move it ectCheap direct drive compressors are hellish noisy, the more expensive belt driven ones are a LOT quieter.
Like this if you have enough room19112010198_s.jpg 72.8K 10 downloads
Posted 22 November 2010 - 09:21 PM
Flash Git!!!
Posted 22 November 2010 - 09:26 PM
PMSL !!!Cheap direct drive compressors are hellish noisy, the more expensive belt driven ones are a LOT quieter.
Flash Git!!!
