Paint For Engine
25 replies to this topic
#1 robby
robby
    Just On Tickover
  • 5 posts
Posted 26 November 2010 - 01:50 PM
hey every1, i want to paint my engine while it out but dont know what paint to use, i was told i could use hammer rite but i not sure about it. any help would be great thanks
#2 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 26 November 2010 - 02:27 PM
Why didnt you just google Engine paint?
http://www.halfords....tegoryId_165495
edit: if you use hammertie on the block i am pretty sure it will burn off. you can use it on the other bits though.
Edited by E.L.M.O, 26 November 2010 - 02:29 PM.
#3 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 26 November 2010 - 04:32 PM
Any high temperature engine enamel paint will do...
Hammerite do make a BBQ paint that will work, because... wait for it... it's High Temperature paint.
Normal paint will most likely burn, as with any painting make sure the surface is clean, really clean, and it will look great. A quick bodge and it will flake off and look rubbish.
#4 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 26 November 2010 - 04:41 PM
Use engine enamel. Not cheap but it will stay on and is resistant to oil and stuff.
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 26 November 2010 - 08:11 PM
Halfords paint is poor on the engine, flakes off after a short while
Tetrosyl do some good worthwhile paint
#6 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 26 November 2010 - 08:36 PM
I have to say that I have Tetrosyl and am dissapointed. The solvent for it is petrol!! and petrol removes it when when dry too. Unless this was a cheap Tetrosyl(good old ebay) but claimed to be enamel,petrol/oil resistant
#7 Barman
Barman
  • 1,068 posts
Posted 26 November 2010 - 08:38 PM
I used this.
#8 1984mini25
1984mini25
  • 8,785 posts
Posted 26 November 2010 - 08:39 PM
I painted up the engine in the 25 getting on for 5 years ago now with hammerite and strangely enough it’s still stuck to the engine block. If the engine block is getting that hot externally that the paint is flaking off, then the paint is the least of your worries. Besides a small 250ml tin will do about 3 engines if used carefully.
#9 Kam
Kam
  • 4,140 posts
Posted 26 November 2010 - 08:41 PM
I had halfords on mine the first time round and it lasted all of a month, I reckon a small gust of wind could of peeled it!
Used tetrosyl second time round and it was fine
Weird
#10 stormintrooper
stormintrooper
  • 2,072 posts
Posted 26 November 2010 - 08:43 PM
I bought engine paint from minispares
#11 pikey7
pikey7
  • 3,824 posts
Posted 26 November 2010 - 08:44 PM
it's all about the degreasing.
i've used normal car spray paint before, and as long as it's cleaned properly, and you don't overheat too much :- then it's never let me down.
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 26 November 2010 - 08:55 PM
Il second that, i doubt my engine was cleaned from the day it was made, went through 3 cans of degreaser and a jetwashing to remove and last bits of grease or soapyness
then painted
#13 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 26 November 2010 - 08:57 PM
my engine and cylinder head was de-greased and steam cleaned, i then painted it with helfords engine paint and its rock solid...why would you try paint a dirty surface anyway?
#14 pikey7
pikey7
  • 3,824 posts
Posted 26 November 2010 - 09:08 PM
didn't think you knew how to clean a car Dave? :-
#15 Kam
Kam
  • 4,140 posts
Posted 26 November 2010 - 09:09 PM
Not dirty but I would imagine most would clean as best as they can with the whole engine out, not everyone takes it apart and gets the full monty done piece by piece, even a few mini based magazines I've seen show a basic clean then apply......
