That’s why he just paints over the dirtier bits each time.didn't think you knew how to clean a car Dave?
Paint For Engine
#16
Posted 26 November 2010 - 09:10 PM
#17
Posted 26 November 2010 - 09:19 PM
I painted up the engine in the 25 getting on for 5 years ago now with hammerite and strangely enough it’s still stuck to the engine block. If the engine block is getting that hot externally that the paint is flaking off, then the paint is the least of your worries. Besides a small 250ml tin will do about 3 engines if used carefully.edit: if you use hammertie on the block i am pretty sure it will burn off. you can use it on the other bits though.
Errr no. My mini runs fine thankya. An engine needs to get up to temperature. If you have painted your engine with hammertire and its stuck then great. but traditionally high temperature paint is used FOR A REASON. Engines run hot enough to strip traditional hammerite. its just what they do.
#18
Posted 26 November 2010 - 09:26 PM
#19
Posted 26 November 2010 - 09:28 PM
Mine has gotten up to temp and boiled over a few times and in now way did it affect the paint. plus the engine/ hammerite paint combo has done a good 12 to 13k of running, so whould have at least fallen off by now.
But going from what your saying that hammerite is useless for an engine block, the same stuff should have burned off my brake callipers as well years ago?
As long as what your painting is properly clean and all the lose stuff is given a good wire brushing after, then it doesn’t matter what you use.
Edited by 1984mini25, 26 November 2010 - 09:36 PM.
#20
Posted 26 November 2010 - 09:34 PM
#21
Posted 26 November 2010 - 09:39 PM
Mine has gotten up to temp and boiled over a few times and in now way did it affect the paint. plus the engine/ hammerite paint combo has done a good 12 to 13k of running, so whould have at least falled off by now.
I never said it was useless.
Going on from what I was actually saying.. High temp paint is recommended, and used for a reason. Again if its worked for you then great. But I have got high temp paint to use when I rebuilt my engine for my pick up. You recommend using normal Hammerite. I recommend high temp paint. different views for the OP to take on board when making their decision.
#22
Posted 26 November 2010 - 09:54 PM
also bought a big tin of gunk so wanted to use its moneys worth
gunk n steam cleaner works very well!
Gotta agree there Gunk is good, I wasn't expecting it to work that well but had to try it out to see, worked well
#23
Posted 26 November 2010 - 09:56 PM
#24
Posted 26 November 2010 - 10:16 PM
The truth of all paint is that it will stand hight temps if it is allowed to bake on in the first place. Overheating even hight temp paint will see it flake of eventually. Always let it cook on slow and harden properley.
#25
Posted 27 November 2010 - 06:29 AM
As above, the integrity of the paint is dependant upon the preparation, not the paint..
#26
Posted 27 November 2010 - 08:41 AM
