Are Smaller Wheels Better For The Snow?
Posted 30 November 2010 - 09:20 AM
hawxie
Posted 30 November 2010 - 09:37 AM
Posted 30 November 2010 - 09:45 AM
Posted 30 November 2010 - 09:51 AM
Posted 30 November 2010 - 10:04 AM
But on ice, just low revs, high gear ect.
Posted 30 November 2010 - 10:10 AM
Coming from a land of snow and ice, I can tell you that narrower, not smaller, is better. More sidewall and a narrow, heavily siped tread, not big blocks. It's about displacement of the water formed continually between the rubber and the ice as you drive. This forms a lubrication layer preventing the rubber from contacting the surface, therefore, no grip. Like the oil in your main bearings. Check the maniacs rallying on ice in Scandinavia, they put 300+ hp through 125 section tyres made by a Finnish bloke to order.the narrower wheels would be best alright because the tend to disperce the snow better from under the wheel better, i would say get snow/mud tyres but i find them not much better if the snow has compacted to ice.... maybe chains or socks might be better?
Modern winter road tyres have air bubbles built into the tread layer to suck up the water at the contact patch and get rid of it by centrifugal force as the wheel rotates. ready to mop up more water at the next contact. At the very least, sipes (cuts across the tread blocks) will help enormously, particularly if there is some snow. And of course, winter tyres have quite different mixtures of the traditional ingredients of rubber, oil and carbon to make the tread more sticky and conforming to any available corrugations on the micro scale.
So, if you are not getting a set of winter tyres, here is the short list:
Stay away from "all-season" tyres as they combine the bad from both, are useless in winter and very poor summer tyres
Get the narrowest tyre with the tallest sidewall and, if the tread blocks are solid, have them siped.
Choose a slippery day and an empty parking lot (Asda on a Sunday?) and drive too fast. Slip around until you have found the confidence to carefully steer and brake out of trouble should it arise!
Posted 30 November 2010 - 10:11 AM
Thinner tires will have greater pressure on them per square inch compared to wider tires. You should be able to cut through snow better with them.
LOW gear!
Posted 30 November 2010 - 10:17 AM
Posted 30 November 2010 - 10:30 AM
LOW gear!
I think high gear is right as it reduced the torque on the wheels, thusreducing the chance of wheel spin.
Posted 30 November 2010 - 10:35 AM
Posted 30 November 2010 - 10:42 AM
Posted 30 November 2010 - 11:36 AM
LOW gear!
Don't say I didn't warn you.
Posted 30 November 2010 - 11:53 AM
Everyone's right!
