Is It Necessary To Have A Damper In The Crank Pulley?
23 replies to this topic
#16 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 06 December 2010 - 04:55 PM
I just thought I would add that last post as a tit bit, not really arguing either way.
#17 mike.
mike.
  • 6,176 posts
Posted 06 December 2010 - 05:10 PM
This is my crank pulley with trigger wheel, also from SD minis so I guess its the same as what the OP has.
This thread has really got me worried now as my dampers been removed for this setup. This is the second setup i've had now, I had a specialist components one which rubbed on the fanbelt and this SD minis one (who i think have now stopped trading) replaces the damper which now it seems will kill my engine!
#18 l_jonez
l_jonez
  • 1,453 posts
Posted 06 December 2010 - 05:21 PM
Ok so is 6 really representative of the 5.28 million Minis made between 59 and 2001 ?
I was not saying that you where wrong in your statement, the early small bore engines did only have a steel pulley and no damper, however it is not just the later 998's that had dampers, I can think of at least 6 different types of bottom pulley that where fitted to the A or A+ engines
just pointing out that not all 998's had dampers :)
#19 MRA
MRA
  • 7,607 posts
Posted 06 December 2010 - 06:01 PM
And that is exactly true :)
#20 adamt117
adamt117
  • 51 posts
Posted 06 December 2010 - 06:07 PM
Thanks for all the info guys. I think for short term i am going to stick with the sd minis pulley but I will probably shell out for the MED trigger wheel pulley with harmonic damper, that way it'll be better in the long run.
#21 Cooperman
  • 23,327 posts
Posted 06 December 2010 - 07:44 PM
To rationalise a bit, if you are fitting a Megajolt is will be to gain performance. If you get more performance you will be driving the engine harder. To drive harder, i.e. use more revs, you will be moving the crank into greater harmonic vibration. Thus a good damper pully really should be fitted.
#22 mike.
mike.
  • 6,176 posts
Posted 06 December 2010 - 08:13 PM
;) That pulley and sensor mount cost me £100.... and the specialist components one I had before that just rubbed on the fan belt.
Is there anyway I can mount a trigger wheel on the inside of the standard damper so I can still use the mount i've got?
#23 MRA
MRA
  • 7,607 posts
Posted 06 December 2010 - 08:22 PM
And that about sums it up really ;)
#24 MRA
MRA
  • 7,607 posts
Posted 06 December 2010 - 08:23 PM
The simple answer is yes, however it depends on how much room you have between the pulley and support bracket, I'll send you a PM.
