obviosly what i said earlier is a diagnostic not a solution, if yon find that it makes no difference then you know that cylinder is not firing, and its an ignition related issue. try swapping the leads around see if it swaps the problem, from that you know its a faulty HT lead, then try swapping sparking plugs, if this swaps the problem, you know its a fault sparking plug, if neither make a difference, you have to start looking into more complicated issues...like Dizzy\valve clearances\lift and compression
Replaced leads and checked they work but connecting to a plug outside the engine, all spark fine.
Also I have 7 working plugs and have tried various combinations to no positive effect. Also cleaned them up and checked the gaps. I know sometimes they can fail under compression but I doubt they all would.
