Megajolt
#16
Posted 15 December 2010 - 11:05 AM
There no moving parts to go wrong, its all electronic. The electrics are much more waterproof and you can place all the electrics out of the way of water spray from the grill.
Tuning wise you can set it up perfectly for your engine, so it has the perfect ignition advance etc at any given revs or load. Once its set it'll never move unlike a distributor.
If you do it right first time, MJ is a fit and forget setup.
#18
Posted 15 December 2010 - 11:59 AM
The trigger wheel is simple enough, it's teeth are equally spaced with one removed (located 90 degrees before the sensor at TDC) : 36 teeth + 36 gaps gives 64 sectors of 5 degrees.
#19
Posted 15 December 2010 - 12:19 PM
#20
Posted 15 December 2010 - 12:34 PM
Both coils have a common +ve, the EDIS unit earths both of them, just like points in a dizzy. You'd connect to the outside 2 wires from the coil pack and feed the tacho via the zener diode.
There's barely a quid's worth of components used & one blob of solder.
#22
Posted 15 December 2010 - 12:43 PM
So, just to be sure - i'd just need to splice that trigger wheels thing into the outer 2 wires of the coil pack plug, and then route it to the rev counter?
#23
Posted 15 December 2010 - 03:05 PM
Thos converter things are a bit of a gimmick i think......
#24
Posted 15 December 2010 - 03:48 PM
#25
Posted 15 December 2010 - 04:00 PM
"Smiths RVI type tachometers
Note that there are two types of older Smiths tachometers: RVI - current sensing, and RVC - voltage sensing. These letters, and numbers indicating exactly which variant you have, are printed in small white lettering on the bottom of the face of the tachometer. RVI type tachometers work by routing the coil +ve supply wire through an inductive loop of wire inside the tachometer, and are not compatible with the MJLJ tach out signal or the tach out signal from the EDIS control module. If you have an RVI type tachometer, you can try routing the power wire for the EDIS coil pack only through the tachometer so the induction windings in the tach can pick up the spark firing events like the OEM system. This has been tested on a 4 cylinder British car with an OEM RVI tach and it gave excellent results. Other options are you replace the tach with a different type, have an add-on circuit board added inside (or build one yourself, see http://www.dinoplex....tachoconversion for a start), or replace all the inside working parts with those from a newer tachometer ie retain the original face, but change everything else. For that approach you need a donor which has the same angular swing per 1000rpm, as the Smiths gauge."
It's certainly worth trying connecting it to the MJ tach output. As a test (with dizzy ignition) you could whip your plugs out, disconnect the HT lead from the coil and see if the rev counter shows any life when you spin the starter. Assuming the engine turns over fast enough.
I'm not 100% sure where the tacho signal comes from, but the MJ has a socketed transistor array (uln2003) as a buffer for the external connections in case you make a booboo. It's readily available for only a few quid.
#26
Posted 04 January 2011 - 10:04 PM
#27
Posted 04 January 2011 - 10:45 PM
Sorry to hijack but didn't want to make another thread about megajolt.
Basically, just a question to anyone running megajolt, are they easily compatable with any if not all of the digiatal guages available on www.Digital-Speedos.co.uk?
Many thanks,
Rich
Just set my KOSO gauge up with my MJ system, and the tach out (blue I think?) wire from the MJ just connects to the tach in on the gauge and works fine.
I set the tach input to high, and changed the cylinder setttings till it worked. Due to the lost spark system on the eids you need to used the 2 stroke setting with 4cyl to get the revs right.
#28
Posted 04 January 2011 - 10:52 PM
