Nooooooooooooooooo!
20 replies to this topic
#1 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 17 December 2010 - 09:39 AM
hi, i got a red light on the 3rd bar round on my xbox, what does it mean and can i fix it without sending it off to get fixed as i want to watch the italian job and i always watch dvd's on my xbox, please help :-
#2 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 17 December 2010 - 09:42 AM
it means send it too me for free!!!! :thumbsup:
google it there are a few different things it could be telling you and there are a few 'how to' guides on the web as well. :- good luck
#3 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 17 December 2010 - 09:44 AM
It's the 'serves you right for not getting a proper console' light
It should go away when you start to cry :-
#4 run115
run115
  • 33 posts
Posted 17 December 2010 - 09:45 AM
had this about two weeks ago, if you are handy with a soldering gun is a fairly simple fix, i found out after spending 30 quid to get tit fixed. Basically the main board gets warped under heat, and the solder gets undone on a couple of heatsinks. Waht you have to do is open up carefully the xbox, find the solder that has come undone and solder it again.
Vince
#5 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 17 December 2010 - 09:50 AM
hi, i got a red light on the 3rd bar round on my xbox, what does it mean and can i fix it without sending it off to get fixed as i want to watch the italian job and i always watch dvd's on my xbox, please help :thumbsup:
Vince
sweet thanks, soldering aint to hard and my dads got a soldering gun thing so im away to try that :-
#6 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 17 December 2010 - 10:09 AM
next question, where bouts is the main board? and ive pretty much got it stripped but i cant get the top of it atm
#7 run115
run115
  • 33 posts
Posted 17 December 2010 - 10:12 AM
You should look towards the part where the mains connector attaches at the back of the console. Thats where the heat sinks ought to be. Hope this helps.
#8 Tommyboy12
Tommyboy12
  • 2,254 posts
Posted 17 December 2010 - 10:15 AM
The motherboard is inside the metal cage surrounded by the plastic shell. You have to remove the entire plastic shell to get at it really. If this console was under 3 years old you should have just sent it away for free.
#9 MrMiniSpecial
MrMiniSpecial
  • 113 posts
Posted 17 December 2010 - 10:28 AM
Type RROD into google and see what it finds...
#10 1380sprint
1380sprint
  • 167 posts
Posted 17 December 2010 - 10:42 AM
I did the towel trick on my son's,
plug it in etc, wrap it up, get it super hot, and it sometimes sorts its self out,
#11 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 17 December 2010 - 04:40 PM
You played that new car racing game,red means STOP green says play.Warm it with a hair dryer.
#12 haggz
haggz
  • 329 posts
Posted 17 December 2010 - 05:02 PM
just to let you know my mate fixes these and ps3. the rrod on the xbox is caused by the paste under the heatsink failing. special paste can be bought from maplins but you also have to change the fixings that hold heatsink down. i have seen him fix one so know it can be done.
the ps3 orange light means the board has overheated and caused a '' dry joint '' on one of the many chips. that job is a lot more complicated but vidoe of fix is on youtube. hope this helps.
#13 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 17 December 2010 - 05:04 PM
my girlfriends brother did this with his ps3, put it in a cardboard box, and put a hiar dryer in there to heat it up to melt the solder again, worked a treat, lasted all of 2 weeks when the remains of the solder that managed to sort it finally melted to much and now it needs resoldering properly!
#14 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 17 December 2010 - 05:14 PM
You could have got this sent to microsoft and back to you in 5 days was free aswell , I did. You cant now though because you've taken it apart .....
Edited by xBR4DLEY, 17 December 2010 - 05:15 PM.
#15 Mattyvole
Mattyvole
    Starting My Mini Up
  • 1 posts
  • Local Club: Not yet.
Posted 17 December 2010 - 08:19 PM
When my old one started playing up (DVD drive didn't like to work), I had to open and repair it every 2 weeks or so. To get the case off, you have to undo the clips under the faceplate, and the clips at the back. The ones at the back are reall [censored] to do. You basically need to stick a little screwdriver (I use optical ones) or something similar into the little slots, until each one clicks. Then the case should pull off.
Then, to get the other side of the case off, undo the six Torx screws shown in this picture:
If you need it, there's a guide with pictures here: http://www.llamma.co...Disassembly.htm
EDIT - you don't need the tool it advertises on that link, it's easier to use screwdrivers etc.
Edited by Mattyvole, 17 December 2010 - 08:21 PM.
