Honda Subframe
Posted 21 December 2010 - 09:44 PM
thanks in advance michael
Posted 21 December 2010 - 10:20 PM
Minitec make them tooi am thinking of doing a honda conversion as my next project and i am thinking of the honda engine but as the title says who makes the kits for this i seam to get allspeed, z cars and watsons then several that are abroad anyone know any more that they can recommend and if possiable what are the good vs bad points of each conversion
Watsons - wide offset so rear needs spacing out and wide arches needed, + bigger brakes can be fitted and wider track can improve handling
Allspeed - Mini suspension is retained and mini brakes, + fits under most standard front ends and standard mini track is retained
I don't know much of the z cars frame
Posted 22 December 2010 - 01:13 PM
Posted 22 December 2010 - 05:33 PM
i would like to avoid a fibre glass front end as i dont get on with the stuff i like metal better so that rule out some of the choices
michael
Posted 22 December 2010 - 08:52 PM
Posted 23 December 2010 - 11:06 AM
Maybe someone should make a thread with links to Honda subframe suppliers and ask the Mods to make it a sticky?? No that wasnt me offering to do it, just a suggestion.
Posted 23 December 2010 - 02:50 PM
Posted 05 January 2011 - 08:47 PM
Posted 15 January 2011 - 10:19 PM
Who does VTEC conversion subframes :
Seven frames are available, the first three will fit standard round nose
Mini track & Suspension setup & will fit standard round nose
1) Allspeed - www.allspeedengineering.com
2) Ringmini.de www.ringmini.de (LHD due to rack issues)
3) American Frames - Brian Campbell
4) American Frames - S Alexander (LHD only) some details can be found on
......................................... http://www.vtecminis...wforum.php?f=22 under the name Steve
5) American Frames - Minitec http://www.superfastminis.com/
Frames 4 to 7 require lengthen fronts or Clubman front
5) American Frames - Minitec old frame http://www.superfastminis.com/
Metro Track/Brakes & supsension
6) Watsons http://www.watsonsrally.co.uk
7) P&L http://www.plmini.co.uk
Metro Track & mini brakes
8 ) SAE http://www.saeminivtec.co.uk
Work in Progress Frames
AMT No Longer producing frames. Please do not contact them.
Streetfighter (work in progress)
Ask Restorations Vtec frame (work in progress) phone 01955 641450
Below are some details of completed frames:-
1) Allspeed (Mini Brakes/Supsension and track & standard round nose)
2) Ringmini (Mini brakes/supsension and track & standard round nose) LHD only[rack issues]
3) Brian Campbell (Mini Brakes/Supsension and track & Standard round nose)
4) Mintec (mini wheel stud pattern, mini track, mini brakes)
5)Watsons (k series wheels or 100 PCD stud pattern large selection, wider track but better K series suspsension)
6) 6) P & L Minis (k series wheels on front and mini on back? and the engine mounts only allows for certain b16 engines eg. 96 CRX, you need to check with P & L over this before buying your engine/frame)
7) SAE (mini wheel stud pattern/brakes/suspension; if standard inlet used, bulkhead needs cutting, K series track)
8 ) S Alexander (Mini Brakes/Supsension and track & Standard round nose) LHD only[rack issues]
Allspeeds frame, Ringmini, S Alexander and Brian Campbells frame keep the same track. They all fit into LHD standard round nose front, Allspeed will also fit RHD but will require a revised exhaust manifold to fit into standard round nose. There will be issues with the inlet manifold clearance and alternator on both BC and Allspeeds frame. Ringmini & Brian Campbells and S Alexander also has issues with the Diff housing hitting the steering rack for RHD. For standard round nose, you will need custom radiators.
Number 5, 6 & 7 on the list above are based around the k series frame and therefore increase the track of the vehicle. As a result you will have to be careful with wheel selection to ensure they fit under sportspack arches(see other discussions on this point).
The normal rear subframe can be used with any of the above, but spacers(not in the normal sense of spacers) have to be fitted - slightly different depending on 5,6 or 7 above, they are however supplied as part of the kit.
Any other questions please make a separate posting and we will try to help
DarrenW
http://www.16vminicl...read.php?t=2742
Posted 15 January 2011 - 11:18 PM
Posted 01 February 2011 - 07:26 PM
thankyou jack jack jack for the info it was incredibly helpful i will be speaking to one of the mods and see if we cant get that made into a sticky somewhere on here
michael
