Roller rockers make a big diff?
Posted 20 December 2005 - 04:54 AM
Thanks!!
http://cgi.ebay.com/...sspagenameZWDVW
P.S. that would equal about 120 pounds..
worth it??
Posted 20 December 2005 - 07:39 AM
What other engine modifications do you have?
Edited by mini mad me, 20 December 2005 - 07:40 AM.
Posted 20 December 2005 - 07:41 AM
Posted 20 December 2005 - 11:37 AM
The only thing i have done is replaced the ignition for electronic ignition with adjustable curves.
Thanks for the help!!
Posted 20 December 2005 - 11:51 AM
They won't give as much of a gain as say a decent camshaft and a new exhaust manifold and carburettor, but they are an often used piece of kit. Have a look on Calvers Corner on the minimania.com website or on minispares.com. He did a review of all the different types of rockers and it makes interesting reading.
Edited by mini mad me, 20 December 2005 - 11:59 AM.
Posted 20 December 2005 - 12:32 PM
I have a stage 1 kit with an rc40 exhaust
Posted 20 December 2005 - 12:34 PM
But they are a very good bolt on when using a std cam.. what I would do is change the valve springs though to some competition ones with fewer turns in the actual spring, because you will be pushing the valve down further you may come across the phenomenom call valve crush.
Posted 20 December 2005 - 12:36 PM
Posted 20 December 2005 - 12:44 PM
A cam change, will have a noticable effect, even on a std head. Not only do they increas the lift, but also the duration ( the length of time the valve is open and the point at which it opens in the 4 stroke cycle )I was told that a camshaft wont make a bit of diff. unless you have a high flow head, is this true? And can a camshaft be changed with the engine in the car??
Even a tame road cam like the 266 is a vast improvement over the std ( and is a fair aproxomy to the addition of increased ratio of the rockers )
but, unfortunately, a solid walled 1275 unit can realy only have the cam changed with the engine out the car, it can be done in with the use of magnets on pushrods to hold the cam followers up, but one slip and a follower ends up in the gearbox, and then thats engine out and splut to retrieve that... which is what you'll have to do anyway... also you'll need to cut a hole in the inner wing to allow you to withdraw the cam... (it's all a bit too fidly for my liking and hence easier to remove the engine )
Posted 20 December 2005 - 12:48 PM
Thanks again for your time!!
Posted 20 December 2005 - 12:51 PM
but before you buy off ebay, look at the minimania websote, and see how much they can supply them for... also ask if the pedestall and rockershaft etc are in the deal ?
Posted 20 December 2005 - 01:11 PM
dont go for silly Ib springs, youll just wear the cam lobes.
Posted 20 December 2005 - 01:16 PM
Hey Neil, are you running a stock head?
Posted 20 December 2005 - 06:05 PM
If you fit new rockers, then idealy you want to fit a new shaft too.
Posted 20 December 2005 - 07:16 PM
