Ultralite 6x10 Deep Dish
Posted 28 December 2010 - 10:20 AM
As im considering getting them and wanted to know what they look like on the car
Posted 28 December 2010 - 04:09 PM
Posted 28 December 2010 - 06:30 PM
if you do a quick search on the net you will find plenty of people who have had the same trouble! i did see one guy, maybe off here, who brought a set off them directly, withtyres, and all was well until he tried to get 2 of the tyres replaced down the line, he had trouble with his usual guys, so went back to MWS and they fitted the 2 new ones, later the tyre bead gave out on the motorway and nearly totalled his car!
the tyre simply cannot stretch far enough to fit on the rim, and as such the bead end up ripping, and it seems if they do manage to get the tyre on after that, you end up with a lump in the tyre wall and eventually a blow out.
i have no idea if the huddersfield wheels are different or not, i believe they are cast differently and dont have this trouble.
Posted 28 December 2010 - 06:42 PM
dont know if this helps
Posted 28 December 2010 - 06:53 PM
Posted 28 December 2010 - 07:01 PM
Posted 28 December 2010 - 07:09 PM
Posted 28 December 2010 - 11:05 PM
Also at the moment iv got 12x6 starmags deep dish does this mean i deffinatly have to change my
Disk or doesnt it depend what size they are?
Posted 29 December 2010 - 10:37 AM
I fitted the the cooper s conversion kit from minisport and it was very straightforward.
Jack
Posted 29 December 2010 - 10:53 AM
If your discs are 8.4" setup then yes you will need to change them, you can either get the cooper s conversion from minisport or minispares, or the fiesta brake conversion can be done.
Jack
Okay thanks mate!!!
Posted 29 December 2010 - 02:15 PM
Posted 29 December 2010 - 07:39 PM
are yours the deep dish ones? if so your litterally the only person i know who has managed it!
Yep
Posted 01 January 2011 - 09:20 PM
out of interest i would like to see the back of your wheels Racer Pete, as im sure yours must be like the ones they had and not the ones i and other had, hence your tyres went on easily.
the ones i saw the other day it was plain to see the well in the wheel was about an inch from the back of the wheel, not smack in the centre like on mine, hence the tyres would be easily fitted from the back, rather than torn to bits trying to stretch the huge distance to the centre.
