Realistic Bhp To Expect
Posted 30 December 2010 - 12:46 PM
I have an idea of what sort of figure I am aiming for to Achieve this but what do you think it will make with the bits I have gathered below.
Thanks in advance Darren
Swift tune SW5-07 camshaft
Swift tune Alloy vernier duplex chain
Hypatec 73 mm pistons
MED 81.3 mm reground, Ni- Temp, Wedged & X-Drilled Crank
Balanced A+ Rods with ARP Bolts
Pierce manifolds Standard Alloy 7 Port Cylinder head
Twin 40 Weber’s
Megajolt
Minis spares ultra light billet flywheel
Minis spares ultra light billet back plate
AP racing clutch plate
Orange diaphragm
Minis pares 4 pin diff
Centre oil pickup
Vandervell bearings
Maniflow stage 2 lcb
rc 40 exhaust twin box
All above have had full rotational balance
Posted 30 December 2010 - 01:15 PM
Posted 30 December 2010 - 01:26 PM
Posted 30 December 2010 - 01:30 PM
I don't know a load about crossflow heads but I wouldn't of thought a great deal over 100bhp with the SW5 cam, you'd be better off with atleast a 286, I'd personaly use a kent 296 SP then you'd be looking at 130-140bhp possibly more
I would have to agree if the figure your aiming for is 100bhp or just over, but if you were expecting more your need to run a bigger cam like the ones suggested.
Posted 30 December 2010 - 01:32 PM
Paul
Posted 30 December 2010 - 01:39 PM
1380cc with the 296 cam
belt drive kit
twin 45s
aldon red dizzy
centre strapped,steel crank and rods
migla manifold
med ld roller rockers
139.8 bhp @7400
108 ft tourque
rolling roaded at slarks
its very drivable compared to a full race 5port,
Posted 30 December 2010 - 01:53 PM
summs116- whats your like at low rpm? and where did you get your head done mine is just as it came form pierce idea was to run it as standard for m and when I want more power get it modded then.
Thanks Darren
Posted 30 December 2010 - 02:08 PM
ect ect the list go's on and on lol
my mate is mad as the engine has already cost him over £6000 and the engine has been out 3 times lol
Edited by minicb, 30 December 2010 - 02:16 PM.
Posted 30 December 2010 - 02:19 PM
Posted 30 December 2010 - 02:23 PM
Are you suggesting that a cam can add a 40% all on its own.I don't know a load about crossflow heads but I wouldn't of thought a great deal over 100bhp with the SW5 cam, you'd be better off with atleast a 286, I'd personaly use a kent 296 SP then you'd be looking at 130-140bhp possibly more
Posted 30 December 2010 - 04:13 PM
The sw5 according to swifts web site will produce more power than a 286 up 5500rpm and as its a road car this is why I plumped for this.
Also missed from the spec list got 1.5 roller tip rockers
Edited by R.S.P, 30 December 2010 - 04:14 PM.
Posted 30 December 2010 - 04:50 PM
Posted 30 December 2010 - 05:31 PM
Hi gents Thanks for the replies my aim was for a real 100bhp not pub talk, I went for the sw5 as I wanted a car that would still drive like a standard 1275 around the town I did consider the sw10 and 296 but did not want an engine that I would have to rev to get it to go.
Thanks Darren
Slarks done the porting and dry decking,i had it mildly ported at 1st and it pulled from 2700 nicely and could drive it round town but was only making 118bhp,so i had it ported out and alot more done,now it 3400 upto 7500rpm,the only problem is that the ports are very big and with the 45s its lost the lower end tourque and it stalls if you come to a fast stop at a juction somtimes,maybe its down to the grey clutch cover and ultra light flywheel,but i built it 4 trackdays so not so worried,i would run 40s and run it as it is and it should b a good drivable 100-115bhp,but is all down to who rollers and sets it up,
Posted 30 December 2010 - 05:43 PM
Not at all, the engine may be capable of 130-140bhp but the sw5 wont rev high enough to produce it.Are you suggesting that a cam can add a 40% all on its own.I don't know a load about crossflow heads but I wouldn't of thought a great deal over 100bhp with the SW5 cam, you'd be better off with atleast a 286, I'd personaly use a kent 296 SP then you'd be looking at 130-140bhp possibly more
I've seen plenty of engines with 286 duration cams only make just of 70bhp then sw5 engines make over 100.
Edited by danrock101, 30 December 2010 - 05:44 PM.
Posted 30 December 2010 - 10:10 PM
what sort of cams are people running and what sort of rev range are they usable at?
