Welding
Posted 31 December 2010 - 04:32 PM
The main problem I am having is when i weld, no matter what settings I have it on it spits and spats weld all over the place, what can I do to stop this, also i keep buring holes straight threw when trying to weld pieces together.
Please can some one help me
Posted 31 December 2010 - 04:36 PM
www.mig-welding.co.uk
i think thats the right website but its brilliant and will basically tell you everthing you need to know
Posted 31 December 2010 - 04:39 PM
Are the practice metal pieces clean and grease-free?
Posted 31 December 2010 - 04:43 PM
Nope he is fine without gas because the wire is cored with flux.
I grided down the metal till all the paint was off, I am using old mini panels I have cut off, is there something else I should be doing to them?
Posted 31 December 2010 - 04:53 PM
It's probably just a case of practice. Mig is not easy to do straight away, it's an art that is only mastered after lots of practice. Some people never manage it !!
Make sure you're holding the torch at the correct angle, and distance from the piece, moving it slowly and steadily.
Posted 31 December 2010 - 04:55 PM
Posted 31 December 2010 - 05:05 PM
i didnt notice he had said flux covered but i didnt realise you could get flux covered wire, i thought flux was only used in stick welding lol but yeh do what boycie has said here but if its flux covered it shouldnt be splattering but if the wire is covered in the sorta flux the sticks are in stick welding it would probably be low hydrogen flux which is the most commonly used, it should only splatter a little bit so im now at a loss if nothing works thats been mentioned before, but try the website i put in an earlier post, its brilliant for learning how to set it up, service the MIG welder and also welding, it helped me get a high mark in my welding assignment in tech
Posted 31 December 2010 - 06:31 PM
Posted 31 December 2010 - 07:39 PM
As said before it takes practice and playing around. Its easier to start on thicker metal. The Mini panels you're using are thin to start with and if you have ground the paint off theyre even thinner now.
Keep the torch cable as straight as possible
Paul
Posted 31 December 2010 - 08:22 PM
Sounds like its 'machine gunning' try turning the speed down on the wire speed, but not silly low otherwise you gotta move your tip a bit quicker
That link above is an awesome help
Posted 31 December 2010 - 08:57 PM
Posted 31 December 2010 - 09:53 PM
Is that saying a mini panel makes its strength from the paintif you have ground the paint off theyre even thinner now.
Posted 31 December 2010 - 11:33 PM
Posted 31 December 2010 - 11:46 PM
he's saying is the guy probably got into the metal as he was grinding off the paintIs that saying a mini panel makes its strength from the paintif you have ground the paint off theyre even thinner now.
also he needs to pulse the weld for sheet metal, like weld for a sec, then stop for a sec, then weld for a sec....ect ect....
also the angle of the tip when welding will help it not have as much of a mess
