Pre Verto Clutch Set Up
Posted 03 January 2011 - 04:56 PM
Hopefully in the next couple of week il be able to put my engine back on the 'box and put it all back together.
This time round, i am changing to pre verto clutch.
Iv got a lot of the bits... Flywheel, diaphram, back plate and clutch plate, but not 100% sure whats next.
I remember seeing a guide on here a while back of changing from verto to pre verto, which tells me what i need to get.
But what im after is some kind of diagram / breakdown of what/why/where everything goes etc, so when im ordering bits, i actually know where and why there going.
Posted 03 January 2011 - 05:02 PM
i know u'll need a pre verto slave cylinder and clutch arm and the pre verto is a different design and can be adjusted, which a verto can not.
not sure if the punder arm on the salver cylinder is different, not sure if thrust bearing is different as well. pehaps some one will know.
there not a bad diagrame in the haynes manual.
Posted 04 January 2011 - 04:10 PM
Posted 04 January 2011 - 04:34 PM
and i think sc parts does diagrams on their websites or moss europe i think, cant remember exactly lol
hope i helped, adam
Edited by Mini Mad Drakeley, 04 January 2011 - 04:37 PM.
Posted 04 January 2011 - 05:34 PM
Posted 04 January 2011 - 05:54 PM
Soo.. from that... i few questions...
6(or 9) x Driving straps 9 ARE ON THEIR WAY
3 x Strap to flywheel screw 3 SHORT AND 3 LONG ARE ON THEIR WAY
3 x Locktab CANT FIND ON MINISPARES..?
1 x Clutch diaphragm assembly GOT 1
1 x Pressure plate GOT 1
1 x Clutch plate GOT 1
1 x Slave cylinder GOT 1
1 x Clutch release bearing FOUND ON MINISPARES
1 x 7/16ths nut and bolt for adjustment ALREADY ONE IN MY CLUTCH COVER
1 x Pre-verto (long) clutch arm FOUND ON MINISPARES
1 x Spring anchor FOR SLAVE CYLINDER END? CANT FIND ON MINI SPARES
1 x Clutch spring FOUND ON MINISPARES
1 x Anchor spring end WHATS THIS?
1 x Pre-verto plunger FOUND ON MINISPARES
1 x Clutch hose ALREADY GOT
Ohh... and a flywheel with you choice of starter ring..
The bits you can reuse from your verto setup are...
The flywheel locking washer and bolt, MINISPARES SAY THEY DIFFER...?? - ALONG WITH LOCK TAB WASHER?
The clutch/slave push rod
The clevis pins
The starter motor
The clutch master cylinder
SORRY TO BE A PAIN
Cheers.
Posted 04 January 2011 - 06:04 PM
Spring anchors...
http://www.minispare...=...5455&title=
and
http://www.minispare...=...9237&title=
infact they were NLA for a long time, so looks like MS have had them remade.
Posted 04 January 2011 - 06:14 PM
Posted 04 January 2011 - 09:32 PM
Regarding the flywheel, are all the pre verto flywheels the same, so i need to put the ring gear on it..?
cheers
Posted 04 January 2011 - 09:36 PM
Edited by bmcecosse, 04 January 2011 - 09:38 PM.
The solution is to go to an utralight on which the pre-engaged ring gear is already fitted and in the right place.
Posted 04 January 2011 - 09:43 PM
How does the ring gear fit on? Having the space the stater wont be a problem i guess.
cheers
Posted 05 January 2011 - 05:18 PM
Posted 07 January 2011 - 04:42 PM
