1994 Corsa Gsi
Posted 04 January 2011 - 07:29 PM
need an engine for my 1994 corsa gsi 1.6 -16v ectotec (water pump failed, belt slipped - clang bang engine now locked up). is there any difference between the origanal engine and say one from a 1997 astra. im not worried about swapping parts over but need to know if the block/head are the same.
thanks, scott
Posted 04 January 2011 - 10:12 PM
I think they had a slightly different head on the GSI to get a bit more power out of it, but for the sake of getting it running its not a big deal.
Posted 04 January 2011 - 10:16 PM
Posted 04 January 2011 - 10:27 PM
try get the same engine again
no piont messing around to be honest
Posted 05 January 2011 - 10:15 AM
This has more power than the later X16 as Burnard says but it's not a major issue. Later Astra Sports etc had an X16XEL, I think differing due to the addition of an EGR valve (been a while since I've played with 90s VX's!)
People used to rave about the C16XE but in reality, most are worn out by now and they weren't helped by a manufacturing issue that affected quite a lot of blocks.. undersize pistons were mistakenly fitted which caused heavy oil consumption/ smoking.
Posted 05 January 2011 - 12:37 PM
instead of trying to find an engine ull think will fit
i was thinking that just swapping engine over would be the cheapest option. i dont think i would have much luck finding a good original. taking the engine apart and reconditioning parts in my opinion would be too expensive. i may as well take the head off and see the damage .
might be a good time to pull my finger out and finish my mini.
Posted 05 January 2011 - 01:02 PM
Same as whats in my mini.
HTH
Pete
Posted 05 January 2011 - 01:23 PM
Posted 15 January 2011 - 05:52 PM
fitted new water pump, timed up etc etc. engine turns over but wont start. engine management light on. im sure it only goes out once engine has started. there is no knocking or grinding so im at a loss as what to look at next.
i know its not a mini but was hoping someone could shed some light on this problem. the haynes manual is a waste of time. could i have the timing 180 degrees out ????? if so how would i know.
scott
Posted 15 January 2011 - 06:00 PM
What does it sound like when it's churning over? You want to hear regular compression 'bumps' while it's spinning, not just a uniform drone.
Do you have a screw-in compression tester?
Posted 15 January 2011 - 06:08 PM
Posted 15 January 2011 - 07:17 PM
Sadly you won't hear any nasty noises, if there's bent valves, they'll be jammed in their guides, probably only very slightly not seating- but enough to lose all compression.
Hate to say it, but it sounds like you have a fair few bent valves, especially if you can't hear the usual compression strokes when the engine is turning over.
There is one other thing- when these sit about for a while, the oil drains from the hydraulic tappets. When this happens, they don't pressurise so when the cam lobe strikes them, they simply compress instead of push the valve open. This is a possibility, but doesn't normally stop the engine firing/ coughing and trying to run.
Posted 16 January 2011 - 09:09 AM
Unfortunately, C16XE engines are getting a little rare now. But, an X16XE will do the same job. The head ports are a little better on the C16XE, but other than that, they're a very similar engine. All of your ancillaries will fit on the X16XE. Only problem may be exhaust manifold and EGR valves. The C16XE didn't have an EGR valve IIRC. Your old manifold will just blank off the outlet in the head on the X16XE though.
Posted 16 January 2011 - 11:22 AM
Posted 23 January 2011 - 09:18 PM
Thanks for now,
scott
