Year:1999
Any non standard parts: 10 inch wheel conversion with 7.5 discs, group 2 arches, hi-los.
There is a high pitched squeak, which sometimes sounds like a scrape, coming from the front passenger wheel.
It comes and goes-sometimes I don't hear it for weeks at a time then it comes back.
When the noise is here it seems to be very bad when doing left hand turns when the mini is heavy laden either with passengers or luggage in the back.
I also hear it lightly when I slow down, either using the brakes or just easing off the throttle.
Every time I take it to a garage the noise disappears but recently I had it in to be looked at and they fitted some longer wheel nuts at the front and also replaced the tapered pin bit that goes through the cv joint. It disappeared for a while after that but now it's back.
I don't think it's the wheel bearing as I had that replaced 6 months ago after it completely crumbled on me.
It's driving me mad, any ideas what it could be? Drive shaft? It doesn't sound like the drive shaft though
