Webber 40 Dceo On A 998
23 replies to this topic
#1 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 05:48 PM
Im looking into buying a webber 40 DCOE for my 998, im just after anything that people know about that combination.
Is it suitable for my engine? easy to fit? woth the money for performance?
Cheers ben >_<
Ignore my typing skills on the title :/ sorry!
Edited by Ben10Raw, 06 January 2011 - 05:56 PM.
#2 oli
oli
  • 128 posts
Posted 06 January 2011 - 07:09 PM
Cant see the point and i'm not sure it would work well on a standard engine. With head and cam you'd probably feel the benefit of the Weber carb.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 January 2011 - 07:11 PM
It's a possibilty once you have improved the engine in many other ways... Would not be my first choice for a carb upgrade - in fact , probably my second last - just before the ghastly 28/36 Weber..........
#4 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 07:22 PM
What would be your choice? im just looking for that bit extra go.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 January 2011 - 07:26 PM
Depends on spec of engine - HIF 38 on a GOOD inlet manifold is fine for an otherwise standard engine - going up to an HIF 44 as the modifications stack up.
#6 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 07:31 PM
okay, just i've heard that the webber does a good job and will gve that bit extra poke, or isnt that the case?
#7 George929
George929
  • 556 posts
Posted 06 January 2011 - 07:47 PM
on a 1275 yes but not on a 998 its will over fuel it
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 January 2011 - 07:49 PM
" will over fuel it " :) Not if it's jetted correctly........
#9 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 08:00 PM
My mates dad knew some one who had that set up and his ran fine. So it got me thinking i could do the same, but run it past yous' on here first :)
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 January 2011 - 08:05 PM
Go ahead - the problem lies in getting it jetted correctly........
#11 danrock101
danrock101
  • 2,478 posts
Posted 06 January 2011 - 08:10 PM
get a modded cylinder head, cooper freeflow manifold, hif38 on a stage 1 inlet, K&N cone filter, and a cam if you have the ability
#12 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 08:15 PM
I have a stage 1 kit, and thinking about changing the cam also. so if i get a new kent cam then the webber will be suitable?
#13 danrock101
danrock101
  • 2,478 posts
Posted 06 January 2011 - 08:21 PM
depends on what kent cam it is, fit a better cylinder head, I still think a hif38 will be good enough up to about 70-75bhp. I'd rather fit twin HS2s than a weber 40 on a 998 personally, generally with engines you want the smallest you can get away with for the power you want
#14 Ben10Raw
Ben10Raw
  • 137 posts
Posted 06 January 2011 - 08:30 PM
Thats the horsepower region im looking towards, i was thinking of a kent 286 cam, what you recon? i was looking at the twin HS2's trying to figure out whats going to be the best for a 998
#15 danrock101
danrock101
  • 2,478 posts
Posted 06 January 2011 - 08:34 PM
A kent 286 will be too much, a 276 would be better... Twin HS2s are great for a 998 but I would use a hif38 to start with.
