Engine Spec Ideas
Posted 10 January 2011 - 07:16 PM
I was thinking
block bored to 1330
sw10 cam
Med stage 2 light weight rotating assembly
Med lightweight flywheel
twin hif44/38
Med s/c roller drops
Med s/c box
or
replacing the sw10 with an sw5 and a mirage turbo manifold kit with t2/t3
Posted 11 January 2011 - 03:19 PM
A SCCR gearbox would also help off the line, with the taller first gear. Aaaand a stronger diff, cross pin would be ideal.
The other option apart from turbo to get that much power, is an 8 port, 16 valve, crossflow head. Look on the Specialist Compnents website. Nitrous, maybe?
Good luck, Paul.
Posted 11 January 2011 - 07:49 PM
replace the sw10 with a kent cams 266 or mg metro cam and fit a gt17Hey guys, i was wondering if you could supply me with a bit of help. At the end of feb my mini is coming off the road for a rebuild and im trying to get a spec list for the engine. it is going to be quite a long project and dont want to skimp on parts. i want to stick with the a series engine but want somthig very quick, so i can suprise tthe posh t***s around me that show off in there ferrari's etc. i was wanting to do a 1330 so that it can be resleeved later on if it needs doing. am just undecided on a N/A engine or going the turbo route. So if you could supply me with your suggestions and possible engine specs it would be appreciated.
I was thinking
block bored to 1330
sw10 cam
twin hif44/38
Med s/c box
or
Posted 11 January 2011 - 08:45 PM
i was going to go with megjolt.
do you think that an sw5 would work with a turbo unit? i dnt have any experience with turbo units so dont know how hard it would be to do.
could any body supply me with an engine spec? either what you currently have or what you would do/could do.
Thanks again
Posted 11 January 2011 - 09:07 PM
i alreday have a cylinder head. 12g940 fully ported and polished with 35.7 inlet and 29 ex.
Thanks again
Im currently building my 1380 turbo motor.
Powermax 9cc pistons
73.5cc bore -1380cc
28cc chamber 12g940 head, stainless valves
Metro turbo t3
metro turbo carb
modified plenum
Kent 266 cam
duplex timing set
metro turbo crank
RS turbo intercooler
custom exhaust
9.1:1 compression ratio
centre main strap
metro turbo crank
going to run 10 psi
Oh and megajolt
Edited by mini_mad69, 11 January 2011 - 09:12 PM.
Posted 12 January 2011 - 02:22 PM
Posted 12 January 2011 - 03:40 PM
Posted 12 January 2011 - 03:58 PM
a t2 would defo give people round your area a run for there money
as they spool up and come "on boost" quicker as they're abit smaller
i'd go for turboi'ing mate
less of the german parts
im gradually doing mine
Posted 12 January 2011 - 04:00 PM
usually the connector goes straight down to the turbo
so no intercooler
with that set-up and 7-10 psi you can get well over 100
my advice is to check out
turbo-mini.co.uk
turbominis.co.uk
a mine of useful info!
Posted 12 January 2011 - 04:23 PM
Posted 12 January 2011 - 06:41 PM
Posted 12 January 2011 - 08:58 PM
If you wish to run 13s quater miles i think you need to think about losing weight in the car aswell as engine
ye iv already got the weight saving ideas down, its just what to do with the engine.
weight saving wise
* strip interior and replace with 6 point cage and some OMP grp bucket seats.
* GRP doors
* perspex windows
* GRP fully removable front
* GRP valance
* aluminium 4 pots
also
* vented a panels to get rid of some of the air build up at the front
was also thinking maybe force racing titanuim front subby and rear beam but think thats going a bit too excessive
Posted 12 January 2011 - 09:19 PM
weight saving wise
* GRP doors
* perspex windows
* GRP valance
* aluminium 4 pots
also
You'd be alot better off with polycarbonate windows instead of perspex, a stripped interior is a good start, but a roll cage re-introduces alot if not more weight back into the stripped interior.
Do you need one for a drag racer?
If your looking at reducing drag, cut holes, or get rid of the rear valance, de-seaming the vertical seams of the car reduces alot of the frontal area of the mini, its around the equivelant of having a flat a4 sized sheet bolted in the air flow.
Are carrying out all of these mods yourself, not trying to be rude as I have no idea of your skills or knowledge, but not knowing what a plenum chamber implies to me that it's limited and that this kind pf project your proposing may require alot more reading. Again not trying to be mean there.
Ben
Posted 12 January 2011 - 10:58 PM
thanks for all your help and knowledge guys, its greatly appreciated.
o yes and the roll cage will be a must as i am planning on using the car on the road and would like to have a bit of protection with having GRP doors etc.
