Cooper S 7.5 Disc Brakes
21 replies to this topic
#1 jeroendewil
jeroendewil
  • 62 posts
Posted 11 January 2011 - 07:20 PM
hai !
I just fitted cooper s brakes under mij 1984 mini .
I just drove it and it seems that his grip in the corners is not as good as when me drum brakes were fitted.
it also lookt that the right site of the car is 1cm higher than the left side but only at the front .
anyone got an idea what this could be?
kind regards
#2 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 11 January 2011 - 07:43 PM
Well the grip problem has little to do with the brakes, although the track of the car at the front will be a little bit wider than with drums.
As for the height difference, i'd investigate the rubber suspension doughnuts. One of mine has sagged more than the other so i have corrected with my hi-lo's until funds allow a replacement part.
#3 Cooperman
  • 23,340 posts
Posted 11 January 2011 - 08:20 PM
hai !
kind regards
Did you also change your wheels to 10" and if so, what tyres did you change to?
The main reason for changing to Cooper 'S' 7.5" discs is to enable 10" wheels to go on.
1 cm height difference is not a lot really and probably not worth worrying about.
#4 Ivor Badger
Ivor Badger
  • 846 posts
Posted 12 January 2011 - 01:14 AM
Did you reset the wheel alinement?
#5 1984mini25
1984mini25
  • 8,786 posts
Posted 12 January 2011 - 01:46 AM
But as the front has now been spaced out more because of the disks, has the same been done to the rear?
If not you need to need to fit the longer wheel studs and rear drums with the built in 1” spacer, as fitted to all minis from late 84-85ish onwards.
#6 jeroendewil
jeroendewil
  • 62 posts
Posted 12 January 2011 - 10:08 AM
hello
thanks for the responses
my mini still has his 10" original wheels.
I was also thinking of the wheel allignement. Is it possible that i have to change the toe setting of te front wheel ?
I now have the cooper s steering arms . Is there any difference with the original ones?
kind regards
#7 jeroendewil
jeroendewil
  • 62 posts
Posted 12 January 2011 - 10:09 AM
the rear is still the same.
I have 3 10" cooper s wheels . Is it better to fit these?
#8 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 12 January 2011 - 10:45 AM
Make sure all your tracking is spot on first. WHat did you change when you went from drums to disc?
#9 jeroendewil
jeroendewil
  • 62 posts
Posted 12 January 2011 - 11:01 AM
i bought the kit at minisport.
this is what i installed new: 7.5" Cooper S Brake Calipers
* Brake Caliper bolts
* 7.5" Cooper S brake discs
* Cooper S Drive Flanges
* Drive Flange screws
* Mintex Standard Brake Pads and split pins
* CV Joints and boot kits
* Drive Flange Collar
* Steering Arms
* Steering Arm bolts and dowels
* Swivel Hubs
* Ball Joints
* Taper Roller Wheel Bearings
* Wheel Studs
I just bolted it on without changing anything else.
#10 jonny f
jonny f
  • 1,485 posts
Posted 12 January 2011 - 11:18 AM
Changing all that i would advise you get the tracking done, to make sure your 'toe' is correct.
#11 Silentbob
Silentbob
    Just On Tickover
  • 5 posts
Posted 12 January 2011 - 01:44 PM
Agreed it sounds like a tracking issue, if it is out, the car will have a tendency to 'push on' as you turn into a bend (understeer). It will possibly not feel as stable in a straight line as well. I expect the steering arms on the S Hubs will be a different length or angle to the old drum ones.
#12 MiniLuke
MiniLuke
  • 1,205 posts
Posted 12 January 2011 - 01:51 PM
I would recommend fitting 4 :strongsad:
#13 jeroendewil
jeroendewil
  • 62 posts
Posted 12 January 2011 - 02:50 PM
:strongsad: they are under another mini i have but there are only 3 cooper s wheels and 1 other :dontgetit:
#14 Timtom
Timtom
  • 2,143 posts
Posted 12 January 2011 - 03:12 PM
I think i need to get my tracking sorted too. My car seems to have some of the symptoms mentioned above.
#15 1984mini25
1984mini25
  • 8,786 posts
Posted 12 January 2011 - 08:45 PM
Then you NEED to increase the track at the rear as well, and then get the tracking checked.
By fitting disks to a previously drum braked mini the front track is now somewere over an inch each side wider than the rear.
