Cooper S 7.5 Disc Brakes
21 replies to this topic
#16 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 12 January 2011 - 08:49 PM
But as the front has now been spaced out more because of the disks, has the same been done to the rear?
If not you need to need to fit the longer wheel studs and rear drums with the built in 1” spacer, as fitted to all minis from late 84-85ish onwards.
the rear is still the same.
I have 3 10" cooper s wheels . Is it better to fit these?
Then you NEED to increase the track at the rear as well, and then get the tracking checked.
By fitting disks to a previously drum braked mini the front track is now somewere over an inch each side wider than the rear.
You can do this by either buying Minifins or just spacered rear drums , up to you and depending on budget.
#17 1984mini25
1984mini25
  • 8,786 posts
Posted 12 January 2011 - 08:56 PM
You can also run 1" spacers with the original drums, but either way you need longer wheel studs.
#18 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 12 January 2011 - 09:01 PM
Yeah , but I wouldnt , would you?
#19 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 January 2011 - 09:02 PM
Alloy spacers are the best/lightest option - as long as they are 'solid' - that's the way to go!
#20 1984mini25
1984mini25
  • 8,786 posts
Posted 12 January 2011 - 09:21 PM
Cost wise its just easer to pick up a pair of second-hand usable rear drums and some longer wheel studs.
#21 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 12 January 2011 - 10:00 PM
Yep you need
Spacered rear drums x2
Normal drums http://www.minispare...ty=pb&pid=35841
Alloy ones http://www.minispare...ty=pb&pid=37940 (note this price is for a pair)
Longer wheel studs x8
http://www.minispare...=...6224&title=
Longer drum screws x 4
http://www.minispare...ty=pb&pid=37541
Once you have fitted it all I would definately get the tracking done
Please note : I have used links to minispares just so you know what you are looking for many other suppliers will be able to offer you the same parts
Edited by Sleepy Stu, 12 January 2011 - 10:04 PM.
#22 jeroendewil
jeroendewil
  • 62 posts
Posted 13 January 2011 - 08:21 AM
is it also possible to fot cooper s wheels like these?
http://www.minispare...ty=pb&pid=38514
