Can I Put 15" Alloys On A Rover Mini?
27 replies to this topic
#1 Goldsmith1994
Goldsmith1994
    Just On Tickover
  • 5 posts
Posted 13 January 2011 - 11:29 PM
Hi guys.
In around 3 months time i will be buying a rover mini but i cannot find any decent 13 inch alloys.
How can i adapt the rover mini to take 15" alloys.
Thanks :D
#2 samini96
samini96
    Secondary account for samini86
  • 110 posts
  • Local Club: Hull Mini Owners Club
Posted 13 January 2011 - 11:33 PM
Put it on 10s
#3 1984mini25
1984mini25
  • 8,787 posts
Posted 13 January 2011 - 11:35 PM
You could stick whatever size you like on it if you really wanted to and did the correct amount of engineering to the hubs, suspension etc to get them to fit and bolt up correctly.
#4 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 13 January 2011 - 11:48 PM
Nothing is impossible but there would be a lot of work involved. The car just wasnt engineered to take 15" wheels. Expect major issues with handling, clearances, and parts wearing out or breaking prematurely due to the extra strain
#5 roofchoplofty
roofchoplofty
  • 95 posts
Posted 13 January 2011 - 11:53 PM
Ive seen this done before, im note sure about the look though.
http://www.minitrailers.com/15.htm
sorry not sure how to do linky thing yet.
#6 Tupers
Tupers
  • 4,160 posts
Posted 13 January 2011 - 11:59 PM
Probably, but only if you tub the rear arches and trim the wings to allow suspension movement or steering. It'd be a good idea to check the diameter of a 15" tyre make sure one would fit in a tubbed arch before you commit to any work though.
#7 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 14 January 2011 - 12:30 AM
Interesting....... so if you have a sportspack its more simple. Obviously not all wheels are the same PCD or off set so the chances that the wheels you have in mind fitting without major mods are slim.
#8 1984mini25
1984mini25
  • 8,787 posts
Posted 14 January 2011 - 12:39 AM
I'm sure Roofless is running 14's :)
#9 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 14 January 2011 - 09:54 AM
I'm sure Roofless is running 14's ;)
yep :)
its all about tyres - if you can find tyres with the same rolling radius as the 175 50 13's fitted to sportspacks your pretty much OK as lomng as you trim bodywork as per sportspacks.
my 14" tyres have a rolling radius of only 6mm more than a 175/50/13 tyres, and have a 45 profile.
im pretty sure you'll find exotic 30 profile and even 25 profile tyres to make 15" wheels work. the ride would be pretty awful though.
I've only seen them on a mini that had heavy modification and honda susepnsion geomettry.
#10 minimanjay
minimanjay
  • 230 posts
Posted 14 January 2011 - 10:00 AM
yep :)
petes running 15" roofless but god nows with pete lol morris the mini
#11 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 14 January 2011 - 10:21 AM
Do they even fit on the back or do they hit the radius arm pivots?
#12 GINO R32
GINO R32
  • 177 posts
Posted 14 January 2011 - 10:39 AM
Mr joshua is on 16'' wheels with no probs
Edited by GINO R32, 14 January 2011 - 10:41 AM.
#13 GINO R32
GINO R32
  • 177 posts
Posted 14 January 2011 - 10:42 AM
16'' wheels
#14 Ben10Raw
Ben10Raw
  • 137 posts
Posted 14 January 2011 - 11:06 AM
10"s all the way :)
#15 mike.
mike.
  • 6,176 posts
Posted 14 January 2011 - 11:19 AM
This on is on 15's: Link
Edited by mike., 14 January 2011 - 11:20 AM.
