Installing a PS2
31 replies to this topic
#1 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 26 December 2005 - 12:21 AM
I've just got a PS2 slimline and i'm wanting to install into the mini :grin: Currently I’ve got a Pioneer headunit, JBL amp and all my speakers are powered through the amp. How can I wire in the PS2 slimline, along with a TV, into my current system so that all sound is played on the speakers? Ay help will be much appreciated.
Cheers, Jam2005 :grin:
#2 binge
binge
  • 2,508 posts
Posted 26 December 2005 - 12:47 AM
Does the Head unit have an AUX input. If not. Forget it.
You could wire it direct to the amp (From the playstation) but it will not have a volume control of any kind.
As for wiring in the TV, All it needs is a +, A -, And a Video feed from the PS2.
<|Ben|>
#3 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 26 December 2005 - 10:17 AM
The headunit is a Pioneer DEH-P5600MP if that helps :saywhat:
Here's a link... Clicky
#4 benfredjosh
benfredjosh
  • 470 posts
Posted 26 December 2005 - 11:07 AM
yes it does have aux inputs
#5 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 26 December 2005 - 11:32 AM
If you got aux inputs then phono for audio goes into the inputs, the video output goes to the screen and you need a 8.5v power supply. I do not know if there are available yet, they were "coming out shortly" last time i checked if not available then you need a voltage invertor to power the PS2 and convert 12v to 240v, but they do drain shed loads of power
Check ebay for cigarette lighter power lead for the slim ps2 as it needs 8.5v.
So if the invertor is the way to go.
This wires direct to the battery (you will get one from Maplin amongst many other places) they tend to have a switch on them so if you leave it on your going to end up with a flat battery.
So I would reccommend wiring it up through a relay connected to the ignition.
When ignition is off then so is the invertor.
Wiring the relay itself is easy
4 wires..
1 earth
1 from the switched live (stereo wire or somthing)
1 from the battery and
1 to the invertor
If you did not have aux input you can still do it using an FM modulator (about £19)
you tune your radio to the preset station and it picks up the ps2 sound signal.
clicky me for the stuff
rgds
shaz
#6 mini_basser
mini_basser
  • 379 posts
Posted 26 December 2005 - 04:22 PM
Correction...it doesn't actually *have* an Aux In...you have the buy the crazily expensive RB20 adaptor for £80
http://www.caraudiod...71d19388f4971b5
#7 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 26 December 2005 - 05:10 PM
http://cgi.ebay.co.u...&category=11319
found this to save you using an inverter.
Just cut the cigarette connector off and add a switch and hard wire it in.
Bob is then your mothers brother.........i think.
Aux input
cheaper fm modulator
#8 philster
philster
  • 1,255 posts
Posted 26 December 2005 - 09:48 PM
i've got a diagram for the pins on a pioneer, you can make your own lead to do the aux, i did and it works fine and cost me about £3 to make.
#9 Saint Matt
Saint Matt
  • 74 posts
Posted 26 December 2005 - 10:26 PM
Not strictly true, most games have a volume control of their own :wub:
#10 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 27 December 2005 - 12:01 AM
http://cgi.ebay.co.u...;category=11319
Aux input
That's great. Will save me purchasing a power invertor :cheese:
How about using one of these for the AUX input into the HU? Clicky
#11 marsden
marsden
  • 169 posts
  • Local Club: www.sheffcruise.co.uk
Posted 27 December 2005 - 01:25 AM
what ever u do dont get the 12v - 240v inverter!, i have just an hour ago witnessed the un needed power it withdraws, it actually drained the battery with the engine running, u can buy straight 12v - 8.5v inverters saving this sort of drain, check ebay, as they pop up on there regularly
#12 empire
empire
  • 63 posts
Posted 27 December 2005 - 08:46 AM
Philster. Could you post the diagram for making a pioneer aux lead please? Hadnt realised i needed to spend £80 for an adapter.
#13 thatluke
thatluke
  • 56 posts
Posted 27 December 2005 - 10:47 AM
You could just save the hassle of making up leads by buying an FM Modulator. Sure, maybe not a great ultra-permanent route, but they're good none-the-less. Basically it wires in series with your aeriel line in, and you plug your audio input straight in. Then you tune one of your radio memories to a certain frequency.. 87.1mhz, I think.. Then whenever you want to play PlayStation, you hit the memory that you programmed into.
Maplin do them for about 20 quid.. I'll try and find a link.
EDIT: Maplin item number: L75AY
#14 empire
empire
  • 63 posts
Posted 27 December 2005 - 12:39 PM
thanks but i would rather hard wire it as reading thru the forums these fm modulators arn't getting much praise.
#15 philster
philster
  • 1,255 posts
Posted 27 December 2005 - 07:46 PM
yeah fm modulators aren't great, they are better than nothing obviously but should only be considered if there is no other option.
I'll post the aux diagram just as soon as i find it lol
