Spiyda Design, Led Lights And Soon, Gauge Parts.
7 replies to this topic
#1 spiyda
spiyda
  • 51 posts
  • Local Club: 16 valve mini club
Posted 27 January 2011 - 04:50 PM
Just to introduce myself,
I've been making parts for Harleys for several years, but branched out to Minis a year or two ago when I started building a Supercharged Suzuki engined Mini (with my son Pete) which you may have seen mentioned in the Forum. Supercharged Suzuki engined Mini or if you want to see the full build diary.. at 16V Mini Club Forum build diary
I started by making modifications to my bike, people liked them and wanted the same so I made some and sold them..
The same is true of the parts for the Mini, I made them for the Mini we were building, people liked them so I made more..
We have been selling on eBay for years, where we have 100% positive feedback, but recently built a proper eCommerce site.
The website is at Spiyda Design
Its all secured by SSL and payment is by PayPal, or Google checkout.
Currently on the site are my High Level Brake Light, as well as LED lights for almost all models of Classic Mini. Pretty much everything is made in-house.
As a welcome to the site, here is a voucher offering 10% off all products, The Voucher is valid, once per customer until the end of this weekend.
Enter this Voucher code "TheMiniForumZX1" at the checkout
I've finally got around to bringing out some new products next week related to fuel and temperature gauges. These have been developed again as a result of needing to make them for our project car. There are some LED gauges to incorporate into your own dash, as well as a fully adjustable fan switch and a device that matches other gauges to our wonderfully unique mini senders !
so visit the site and sign up for the newsletter so at least you see the new products as they are ready.
I'll add some pictures to the post later, but they are all there on the site.. so go visit !
Chris (-=Spiyda=-)
Edited by spiyda, 27 January 2011 - 11:46 PM.
#2 spiyda
spiyda
  • 51 posts
Posted 30 January 2011 - 07:30 PM
Just a reminder that this 10% voucher expires tonight "TheMiniForumZX1"
Chris (-=Spiyda=-)
#3 spiyda
spiyda
  • 51 posts
Posted 13 October 2011 - 02:57 PM
We recently reduced the diameter of the supercharger pulley on our suzuki engined classic Mini...
now running over 11 pounds of boost..... near enough 20% more power !!!!
The pulley was made by us on our CNC lathe and fits onto the Eaton M45 the same way as the original...
It was machined from Mild Steel rather than Aluminium (like our water pump pulleys) for wear resistance
I will be adding a section to our website for custom pulleys in the next few days..
We can now machine any kind of PK (multi-rib) pulley as well as the more conventional Vee belts pulleys..
happy to do one-offs
if you need something special.. use the website contact form
Chris
Edited by spiyda, 13 October 2011 - 02:57 PM.
#4 ZKruly87
ZKruly87
  • 114 posts
  • Local Club: Mini Wips
Posted 13 October 2011 - 04:16 PM
Just thought i would mention that have purchased Spiyda's full LED kit for my car. The kit is extremely well built and fits perfectly. I could not be happier. And the Led are all extremely bright including the brake lights. The reverse lights are almost blinding at night time. lol
#5 spiyda
spiyda
  • 51 posts
Posted 21 February 2012 - 04:03 PM
Someone contacted me last week and pointed out that we didn't make an LED light insert for the front indicator/parking light on the MK1 Export mini
We do now ! and as far as I know we do versions for every model of mini (except the elf/sprite/moke)
http://www.spiyda.com browse to the mini LED lights sections
The latest board fits into the dual filament lampholder with the white lens
instead of being stuck with a white parking light and a white indicator (as designed)
this unit gives you a white parking light and an AMBER indicator !
Like most of our LED lights, it uses 10mm wide angle 0.5 watt LEDs as used in commercial vehicle lights.
Besides replacing the bulb in original fitment Export models,
this could be used to do away with the parking lamp in the headlamp
In case anyone wants one, the dual filament indicator unit is available in a plastic version very reasonably
part No. 1B9100MS
from (I have no affiliation with these companies, they just happen to sell the part)
http://www.minispare...ty=pb&pid=33385
http://www.minisport....au/prod918.htm
www.minimail.co.uk/products.jsp?q=&p=5 about 13 items down
Edited by spiyda, 21 February 2012 - 04:07 PM.
#6 leaky
leaky
  • 6,890 posts
Posted 21 February 2012 - 04:57 PM
I also have a set of the tail light ones on the back of my clubby! Very good bit of kit indeed. I keep meaning to get round to ordering the Clubby front units.
#7 spiyda
spiyda
  • 51 posts
Posted 01 June 2012 - 10:36 PM
Latest addition is a pin compatable voltage stabilizer to replace the Lucas 1303/20 three pin unit fitted to the 2 and 3 clock smiths clocks..
just unplug the old one and plug this in it's place.. fixes a variety of fuel gauge / temperatur gauge issues.
We will be bringing out versions for the central speedo too in the next weeks or so
The stabilizer is on our website and on ebay.
http://cgi.ebay.co.u...em=380444229121
and
https://www.spiyda.c...-br1303-20.html
#8 warning634
warning634
  • 488 posts
Posted 06 August 2012 - 10:12 AM
Hi all
I just thought I would post some pics of the mk II led kit fitted, which I must add was very easy to install and came down within 2 days!
So go on treat your mini :)
Kevin
