Hi all,
I have a heelboard replacement end panel from Magnum, but I have found out from here that it has metric captive nuts on. It also does not have an inner sill support section. I am thinking ahead a little and is there a better panel to change to with..
1. proper mini nut sizes
2. the inner sill support piece
Many thanks,
Graham
Changing A Panel
grahama
, Jan 27 2011 08:12 PM
1 reply to this topic
Posted 27 January 2011 - 08:12 PM
Posted 28 January 2011 - 03:42 PM
You could try these SUBFRAME MOUNTING REAR PA...HMP441006 this is from Minispares and its a Heritage item. Its the half piece not just the end.
If you can make your own bracket, use 1.2mm thick steel for that then weld on 5/16 stiff nuts.
I did find the Magnum panel we originally bought for Erm was a very very poor fit and would have needed to be cut around plus metric nuts. However in the end i replaced the complete heelboard with the Heritage one.
