Metro turbo engine.
Stripped as follows: -
Head has been stripped & previous owner has started to port it, I had it welded up as the porting went very close to the valve stem pocket & rough shaped it, needs finishing & polishing.
Block completly stripped, water pump opening opened out to increase flow, 1 core plug removed for dry decking, no holes were drilled just measurements taken.
Gearbox removed but still complete.
Comes with rockers, valves, rocker cover, pistons, cam, crank, clutch, flywheel, all nuts & bolts.
No dizzy, turbo or inlet manifold.
All parts are there & you dont have to strip it as its done for you!
Any question please ask.
Pictures upon request.
£300 no offers or I'll stick it on e-bay.
Mg Metro Turbo Engine
minibarmy
, Jan 30 2011 06:22 PM
1 reply to this topic
