Med 1380 Engine - Whats It Worth?
13 replies to this topic
#1 shep_cobain
shep_cobain
  • 157 posts
Posted 02 February 2011 - 05:45 PM
# med 1380 engine
# Running Polestart remappable (ignition) ecu, trigger wheel and crank sensor complete ford coil pack
# minisport stage 3 head (37mm inlet valves and 29mm exhaust valves)
# 1.5 roller tip rockers
# med ultralight flywheel verto style clutch (inc med cnc centre bolt)
# centre main strap
# centre oil pick up
# kent 286 cam
# arp head studs (nine).
# Single Weber 45 jetted to 1380 (brought brand new 6 years ago)with K&N Filter
# Weber twin cable accelerator mechanism
# 13 row oil cooler and braied hoses.
# Quick shift and complete remote assembly
# Stainless Steel LCB with heat wrapping
# duplex timing gear
# fitted with thermostat blanking sleeve.
# TranX Straight cut gearbox and 1:1 drop gears
# Brise high performance alternator 55amp
# high torque, compact, light weight starter motor
# Fitted with a massive front radiator (larger than the MPI ones) and a header tank and a pacet fan
# Red top facet electronic fuel pump
# King fuel /filter regulator unit
Just wondering what this is worth if sold complete.
Or what is it worth if it was running in a mini?
Edited by shep_cobain, 02 February 2011 - 05:46 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 02 February 2011 - 06:29 PM
I've had to think about this.....
£1500 give or take...
in a car, worth nothing, and quite possibly worth more than the car it's in...
#3 shep_cobain
shep_cobain
  • 157 posts
Posted 02 February 2011 - 06:56 PM
so this is overpriced?
: Mini 1380cc
#4 stickycreambun
stickycreambun
  • 1,865 posts
Posted 02 February 2011 - 06:59 PM
Id have said it was a bit yes.
:thumbsup:
#5 shep_cobain
shep_cobain
  • 157 posts
Posted 02 February 2011 - 07:08 PM
i offered, £4k and he said he could get £3.5k for the engine on its own...
#6 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 02 February 2011 - 07:16 PM
i sold my whole car for 3.5k, just leave him to it :thumbsup:
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 02 February 2011 - 07:22 PM
Oh dear!!
Leave him to it.
Your offer of £4k was a very very strong one!!
I'd have said more around the £3.5k mark and thats to the right buyer with the wind behind it.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 02 February 2011 - 08:10 PM
I thought the spec looked familiar.... which is why I had to think about it...
working on the basis that is was of unknown origin, history and build quality then that's about what I would expect...
however, I know the car... I'll not defend the asking price, but it is one of the best looking, sounding and performing minis I've seen or heard...
#9 shep_cobain
shep_cobain
  • 157 posts
Posted 02 February 2011 - 08:43 PM
The car has a couple of niggles with the body work which the seller has informed me about. He said hed take £5.3k with them sorted. lol
I think ill stick to spikeys 1340cc.
#10 Shifty
Shifty
  • 13,154 posts
  • Name: Sean
Posted 02 February 2011 - 08:50 PM
Yeah, I did notice that the bonnet didn't sit right, also the fitting of the wings looks a little messy.
Were the sills and inner sill replaced correctly, ie vented sills and full length inner sill panels(not the over panel type)
The boot lid doesn't look to be sitting quite right either.
Was the engine actually built by MED or from a kit?
#11 shep_cobain
shep_cobain
  • 157 posts
Posted 02 February 2011 - 09:54 PM
Is it worth it though John as he says he has a unit opposite yours and you know the vehicle?
He says he knows MED personally and they built his engine.
Edited by shep_cobain, 02 February 2011 - 10:03 PM.
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 03 February 2011 - 07:14 AM
I think you need to see/drive the car and make your own mind up...
#13 minisprint
minisprint
  • 1,036 posts
  • Local Club: GR8 minis
Posted 05 February 2011 - 10:01 PM
How you guys value a car from pics and without driving them?? Seen this mini and had the pleasure of driving it on more than once! I don't think anyone could buy or build such a high spec mini for the price of 5000. If you don't want to buy don't waste the poor blokes time with stupid emails! If you are seriously interested go and get adie to give you a ride and I garantee you will come back with a :-)
#14 myminimonster
myminimonster
  • 72 posts
  • Local Club: great minis
Posted 15 February 2011 - 08:34 AM
Thanks for the kind words Chris & John.
