Ford Ka Dashboard
Posted 06 February 2011 - 05:56 PM
im thinking about doing the Ka dash conversion, im not shy of hard work, and im pretty good with fibreglass etc, but want to know whats involved!? does anyone have pictures of doing this? any personal experience will help at this point!!
many thanks
Posted 06 February 2011 - 06:48 PM
Google it and check out how others have fitted them. Usually its shortened around the dash pocket as its much easier
Posted 06 February 2011 - 07:04 PM
his KA dash is awesome even the edidtor of mini mag said it was the best he'd seen.
hes got loads of pics and i believe hes still got on of his earlier attempts which he used first, then got a secong to do "properly" for the install itself.
Posted 06 February 2011 - 07:10 PM
Posted 06 February 2011 - 07:30 PM
what were you paying for yur dash's have emailed a few people breaking KA's, only one got back to me so far, and wanted £150!!! seemed a bit steep! you have used the standard mini dials i see, thats what i was goin to do, did you find the dash sat in the right place for them, because dont really want to be re-wiring the dash pod if i can help it....
have you just cut a bit off both ends to get it to sit correct then fibreglass and smooth off after?
how have you attatched it? fabricated brackets, or has there been logical places to attatch when its in?
guess most of these questions will become obvious when i 1st try to line everything up!!
Posted 06 February 2011 - 08:13 PM
sorry if there is already a topic for this, but hard to find as cannot use the search engine on the word "ka"...
many thanks
as H4WX1E said, the main problems to overcome is the gear leaver and steering wheel, from my PMs with H4WX1E, he cut alot more of the dash out to get it to sit back nicely so it didnt touch the steering wheel, I went with a dished wheel option and bent the gearstick and cut less out of the dash.
I cut the pasenger side vent off and trimmed the drivers side and it fits nicley, others have cut a section out the middle and rejoined it.
you can get a dash for about £70 from a breakers including all the bits.
You can attach it to the upper and lower dash rails by making up some brakets.
Took about 10x longer than I was expecting though, mainly because I did a digital speedo and rewired the whole lot!
Posted 06 February 2011 - 09:31 PM
Posted 07 February 2011 - 12:54 AM
many thanks
this kind of gives you an idea at what I cut out
standard wheel shows the kind of clearance problems
just clears the heater
IMG_4631.JPG 261.92K
95 downloads
Posted 07 February 2011 - 10:03 PM
Posted 07 February 2011 - 10:44 PM
Posted 08 February 2011 - 12:00 AM
I've got a Ka, why would you want to do this haha, they're fugly pieces of horrible plastic!
in a KA, they do look a bit cheap and plasticy, I havent seen one yet that has been left as plain plastic though, they are different and make the interiour feel less edgy
each to their own I guess
Posted 10 February 2011 - 01:45 PM
Posted 10 February 2011 - 08:22 PM
Posted 10 February 2011 - 08:46 PM
why dont you make a build thread then? wish i had with mine, suppose i could always put one up from the beginning to the end of me build.
Go for it, your help was invaluable when i did mine.(even though i didn't use the dash after all)
Posted 10 February 2011 - 09:20 PM
