Rear Camber
#16
Posted 18 September 2011 - 06:54 PM
why would you want that much neggy camber? an f1 car only used 4 at the front!
either youve got your figures wrong or you dont know what makes a car handle well
#17
Posted 18 September 2011 - 07:01 PM
5.0 degress negative camber? how many tyres do you go through a week?
i think its different to what car spec it is, i see BTCC cars with 8 degrees on the wheels just for driving preferences. but 5 on a mini!?! wowzers.
#18
Posted 18 September 2011 - 07:04 PM
That's the only reason why I've not got any for mine yet as I don't fancy having to remove the subby to get some new bolts/studs put in.
#19
Posted 18 September 2011 - 09:48 PM
You will need to make sure that the rear wheels toe in slightly. Toe out is bad.... Very nasty oversteer and a quick trip to the hedge!!!
ah they toe in quite alot actually i can see by eye, but i may still get it set up i know a local place thats pretty good i got my daily driver set up there
i have about 5 degrees neg camber all round handles beautifully
Hey I just got adjustable rear negative camber brackets and was wondering if you could post pictures of your massive 5.0 degree neg camber so i can see how mental i want to go with mine : )
#20
Posted 18 September 2011 - 09:55 PM
I think you got your eye measurements wrong !!! 5 deg is ridiculous. i raced minis with falcons on and the most we ran on the front was 3.5 deg
#21
Posted 26 September 2011 - 08:15 PM
Bits of string really doesnt give the same results...But someone here will tell you how to set it all up with a bit of string.....No really.... and it gives the same end result...
No really you havent...and no it wouldnt!
#22
Posted 26 September 2011 - 08:44 PM
One thing I do wonder, when people on here talk about 'handling' do they mean 'handling' or 'road-holding'? They are not the same thing. A car can have great handling but poor road-holding and vice-versa.
