Engine Spec, What Would You Change.
#16
Posted 08 February 2011 - 08:00 PM
#17
Posted 08 February 2011 - 10:20 PM
thanks matt
#18
Posted 08 February 2011 - 10:40 PM
#19
Posted 08 February 2011 - 10:59 PM
There you go again.......... it's got nothing to do with limiting factors.
The 1380 will breath heavier which will increase the port velocity and hence increase the torque at the bottom and mid range..... I have not even mentioned the higher RPM were any restriction may cause a slight loss of BHP..
Restrictions are only an issue when higher revs are concerned as you need to cram in air faster, more fill ups per minute...
Try drinking cola with a 1" (25.4mm) straw.... how effective is it ?
Now try with a 1/4" (6.35mm) straw and see how better this is....
Well it is similar when trying to get air in to a slow revving engine ie at 2000rpm or so.
BMCECOSSE, can you talk with experience or are you just guessing, as reading your posts above it is blatently obvious that you have never driven or owned a 1380.
Edited by mra-minis.co.uk, 08 February 2011 - 11:02 PM.
#20
Posted 09 February 2011 - 10:31 AM
Also anyone run a 1380 on twin hs2? or do most go with a bigger carb?
thanks
#21
Posted 09 February 2011 - 11:43 AM
the forces acting on the pistons due to increased power/torque also reduce the reliability...
However I believe the OP will be more interested in the lower end torque characteristics, so an AE piston would give more than enough reliability. As long as the ignition and fuelling are sorted out.
#22
Posted 09 February 2011 - 12:49 PM
It's not only wear you have to look out for it is also fatigue failure, due to cyclic stresses, these stresses increase exponentially along with the increase of RPM.
What sort of rpm would you expect from a build like this, I thought that lightweight flywheel and the cam would mean an engine that will be revvy and cammy ? Does anyone run Ae powermax on a high revving engine ?
#23
Posted 09 February 2011 - 04:13 PM
Thanks Matt
#24
Posted 09 February 2011 - 08:30 PM
The best pistons I've ever used are Karl Schmidt, but the last set I found, at +0.040", cost me over £500 for the set.
It is good to fit a cms if you are going to rev over about 6500 on a regular basis and they are low-cost to do.
A close ratio gear kit with a 286 is good, but it makes 1st gear very long and a 3.44 fdr or lower is needed. Probably a 3.76:1 fd if traffic driving is involved.
The 1330/1380 issue is really about the continuing availability of 1275 A-series blocks. Although in theory you can bore again from 1380, it is by no means guaranteed and it is possible a 1380 block may be scrap when re-bore again time comes around. With a 1330, at re-bore time it can be sleeved back to 1275. Apart from that the only other minor issue is the head gaskets on a 1380, but that may not be an issue with the latest gaskets. It is important that the machine shop understand about offset-boring to get to 1380. Don't laugh, but I recently had an engine brought to me which had been bored to 1380 but not offset. The so-called 'expert engine builder' had also bored/honed it on average 0.004" oversize and it just threw its oil out. The block could not be bored again as it was not offset and was thus scrap. An expensive exercise all told.
#25
Posted 09 February 2011 - 09:00 PM
#26
Posted 09 February 2011 - 10:19 PM
You seem determined to challenge most of my posts.....I thought it was an open forum where folks calmly discussed problems. There are bound to be differences of opinion - and varying experiences to be offered. I shall continue to offer my views where I think they are helpful and may assist others to avoid wasting money!
#27
Posted 09 February 2011 - 10:26 PM
Slark race engineering in Amesbury.Can anyone vouch for any good engine builders that I might not have thought of ? If they are in the south even better, or info on any engine kits ?
Thanks Matt
#28
Posted 09 February 2011 - 10:57 PM
Yes MRA I had a 1380 and it cracked between 3 and 4. So for me - it's a risk not worth taking for a tiny extra advantage.
Roy I have sent you a PM with regard to the above statement
I only challenge those that are either dangerous or simply incorrect.
We are trying to get a forum that gives explanations and proof not simply heresay
one bad example of an engine and its all bad never again etc...
My first Mini broke down on me on the way from buying it, should I have swapped over to Fords etc.. ??
Read the beginning of this post, (the bit in pink)
For me personally as a Moderator and Trader, the Moderator hat is the main one whilst I am on this forum, you will see that I don't recomend the fitment of the CMS however we manufacture them, We stock Omega and AE pistons I always try to steer a customer down the reliability route..... power without reliability is nothing !
#29
Posted 09 February 2011 - 11:54 PM
Thanks Matt
#30
Posted 10 February 2011 - 12:03 AM
