Replaced the ball joints on the white mini 2 days ago and it felt a little tight but
after a few miles it felt a little easier (but was still tight).
Had a word with the MOT tester and he said no problem they will free up.
Went back in the evening and the car failed the MOT for the ball joints being too tight.
I have put the shims in there all 3 of them on each joint
But it still feels tight, am i needing extra shims or is there something not right ?
I slackened them a little more but it seems anything more than a nip up of the large nut tightens them to the point the steering becomes stiff, when you drive round a corner the steering wheel does not return to the centre without a bit of force.. fully greased and no parts missing...
any slacker the large nut turns with the steering.. possibility of working loose, so not keen on that..
I suspect i need more shims, but looking for any advice you can give..
cheers
shaz
