steamy windows
Posted 22 April 2004 - 02:55 PM
Posted 22 April 2004 - 03:15 PM
Posted 22 April 2004 - 03:48 PM
Siggy
Posted 22 April 2004 - 03:54 PM
Posted 22 April 2004 - 03:55 PM
Posted 22 April 2004 - 05:25 PM
You'll probly find its either a leaky window or small hole in the car somewere or door seal thats letting the water in and because your carpets are wet, they steam the windows up all the time.
Or it could be one of the two heater hoses arent quite tight enuf on the heater, they tend to drip a bit when the hoses start perrishing. Also sometimes the pipe that goes into the heater matrix can crack and leak from there.
Posted 22 April 2004 - 05:40 PM
Posted 22 April 2004 - 06:48 PM
on all the cars I've owend they have come with two buttons in the controls;
1. circulating the air internally and
2. ciruclating external air into the car
when it rains if you have button 1 pushed then the windows fog up something nasty, as it's keeping moisture in the vehicle.
the thing I've noticed about my mini is that it's lacking this, and all it has is a hose running from the heater to the sill on the passenger side for fresh air.
you've noted that when the windows are open it stops the fogging as fresh air is being circulated into the car.
you should check to make sure that this is properly connected and that your heater isn't clogged anywhere, as in air passages, etc.
I'm not an expert at this, as my ultimate solution was to rip my heater out, as I don't drive it in the winter, and don't plan on driving it in the rain, as it's allergic. lol.
best of luck.
Posted 22 April 2004 - 07:13 PM
on a serious note! have a look at the heater hose coming into the car for shaffing of the pipe, where it comes into the car, you might have a small hole that only leaks when the car gets hot enough, plus as lostininglewood said "check the inlet hose for the heater to see if it hasn't came apart under the right hand wing somewhere......
p.s. hows uni going ???? :grin: :wales:
Posted 22 April 2004 - 09:36 PM
what i'd do to be sure is start your car up, or just go for a drive, go for at least five mins, so your car is up to a normal temp, the water system on your car will be pressurised now. park up , leave the engine running with the heater on hot, get down on your knees and have a good look at your heater.
you should be able to tell pretty quickly if its one of the pipes going to the heater, thats leaking......if these pipes are dry, put the heater flap onto the car setting (not the screen setting), and poke your fingers in the hole where the hot air comes out, if its wet in there, the heater core is leaking.
if your not loosing much water, the chances are the leak is small, so it would be easy to fix in the short term, stick a bottle of radweld in the radiator, and let it do its stuff, this will last a good few months. in the long term your going to have to change the heater core, i think new ones are quite dear, so it may be easier to change the whole heater assy with one from a scrappy/mini show.
Posted 22 April 2004 - 10:32 PM
Posted 22 April 2004 - 10:39 PM
When I get back from Amsterdam I will write directions on how to find leaks
Siggy
Posted 22 April 2004 - 10:46 PM
this site is rude!
one lad has a steamed up window......another is off to amsterdam
my mini steams up........but thats because its a mini.........the heating is *******!
Posted 23 April 2004 - 03:38 AM
Hey I aint getting steamy in a car with no girl thank you!!!!pal...steamed up windows usually means stop getting naught wiv the misses in the car
And siggy It instantly steams up when I go right, Eg when im going on the last exit of a roundabout etc!!
But thanks guys for the info, see if I can pop back to my parents this weekend to she what she up to. :wink:
Hey Buzz (cowboy) unis going well, having some late late nites at the mo and drinkin stupid amounts of vodka, went to a huge gay night club tonite, well it was an experience, put it this way, I'l try not to smile at to many girls next time I go to one they seem to get the wrong impression!!! :cheese:
Posted 03 May 2004 - 11:57 PM
